Turbo without AFC? What will happen?
What will happen if I run my car without the AFC hack or POT unit method? Will anything go wrong? I'll be trying it with the stock injectors, then the DSM 450s. I do plan on getting a rigged up unit though, just gotta drive it for a few days to school and back until I do.
[Modified by OKSolSi, 7:21 PM 5/11/2002]
Re: Turbo without AFC? What will happen? (OKSolSi)
As soon as boost hits, you'll throw a code. If you try it with the dsm 450s, you probably wont be able to start it, let anone idle it.
I would leave it with the stock injectors, and try not to get into the boost range. If it does, you'll throw a code and need to restart the car.
Or course, the smart thing to do would be find alternative transpertation
Re: Turbo without AFC? What will happen? (RioNinja)
I will be able to start and run the car with with the 450s in it. I already tried it without the turbo in and everything ran fine until I hit 6k RPM. So should I just put in the 450s?
SOHC_MShue
09-20-2004 03:02 PM
freeplay
09-18-2002 09:42 PM
