Turbo timer killed car..help
I installed the greddy turbo timer on my 93 civic ex and after about 2 hours of driving the car cut off while in idle and neutral. I connected the wires right because the turbo timer worked. I connected the wires to ignition 1, ig2, power and ground.
Now the car will not even turn over and i dont get any accessory power(like power windows or wiper power) I don't think its the starter because the car was running and then just died without any warning. Thanks for you help. |
Re: Turbo timer killed car..help (Turbo EG)
check all your fuses and connections seem to be electrical problem.
Check all your under hood fuses. Sounds like you blew something. I did that this weekend while relocating a kill switch i have installed. Blew the main ECU fuse and the car wouldn't start. Kinda had me worried for a bit untill i figured out what had hapened.
Mike |
