turbo stock b18c5 motor
ok i was woundering how much power a stock internals type-r can handle on a daily basis? i wanna have a 400 WHP with a pump gas turbo type-r motor. i never see or hear of anyone running a turbo on a stock internal type-r motor. i'm using the inline pro 3mm head gasket and a stage 4 full race set up victor X manifold 70mm throttle body 660 injectors and having jeff evans tune the car i made the appointment. i was just woundering what to exspect from the car when i get it tuned.
Re: turbo stock b18c5 motor (b18bucket)
you better off asking jeff evan
i believe he wont tune your car to 400hp since your internals are stock and pump gas
theres alot of stock turbo R in the board
stock internal limit is around 300hp depending on how beat the motor is
Re: turbo stock b18c5 motor (beerbongskickass)
boost stock itr motor 7-8psi or so like itr206 that was his old honda-tech name...make about 300whp...
compression plays a big role but it all lies in tuning
i am at 10:1 with a gt35 pushing 366whp...at 15psi...
I think the big isue with this engine is that it has a wery small "piston to wall" clearence.
Once you turbocharge it and run it hot the pistons will increase size a bit and piston will cut the sylinderwalls.
the ITR engines has forged pistons as well, but thin rods and high comp.
read here:
http://www.superhonda.com/tech....html
(In order to increase compression ratio, the side molds of the pistons were increased. (Pent-Roof-type Piston) The inside was shaved to balance out the total weight, and the aluminum pistons were forged in order to retain precision.)
I supose they can handle boost in moderate propotions, with the right tuning and fuel.
read here:
I made 295whp on a Mustang dyno at 10 Psig boost on bone stock internals. The motor lasted for 40K boosted, it probably would have lasted longer had I not played around with crappy 'tuning' methods, I should have gotten the Hondata right away. Anyways, it's a great low boost candidate. I'm currently building a forged internal GSR motor for it. Good luck with your setup.
Re: (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec »</TD></TR><TR><TD CLASS="quote">
Re: (atec)
umm no they dont lol
Re: (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec »</TD></TR><TR><TD CLASS="quote">I think the big isue with this engine is that it has a wery small "piston to wall" clearence.
read here:
another example on how you cant always believe what you hear on honda-tech
read here:
Tmnjlb123
09-08-2014 04:38 AM
tegman23
04-10-2007 05:13 PM
99blackdc2
09-04-2006 07:47 PM
