TURBO SET UP NOW NEED HELP TUNING!!
Hey Guys,
I have a d16a6 t3/t4 set up. everything is fine just need to fine someone that can chip and street tune my obd-0 pm6 ecu. I made sure that ecu can be chipped it has the slot for 28 pin eprom.
I NEED IT BY THIS WEEKEND THANKS GUYS!!!!!!!
Re: TURBO SET UP NOW NEED HELP TUNING!!
Check here in the directory to help locate a tuner near you.
https://honda-tech.com/forums/forced-induction-16/%2Anew-tuner-directory%2A-2349805/
Good luck.
Good luck.
I doubt you will find too many people who will tune your car for less than $350. Especially if you want it done right. Tuning is the last thing you want to skimp out on. Save some money and do it right the first time.
Another note, do NOT try & skimp out on tuning your car. That is THEE most important aspect of a boost build. If you dont have the cash at the time, be patient & save up for it. You'll thank your car in the end.
EDIT: Good choice, Shawn Church is one of the BEST in the business, you'll be in good hands.
look into evan tuning they have a program now its a "e-tune" where they send you a base map and get you running , you continue to send them data logs until the tune is spot on, knowing evans and his reputation its something to consider...i beleve its arround 150 bucks or so...
