Turbo Sand rail
Turbo Sand rail
Hey guys,
I have a 3.2 vtec in my sand rail and I was thinking about bolting on a turbo for it. Any suggestions on a kit.
Thanks
Thanks
Moderator
Re: Turbo Sand rail
I saw that in the other forum.. fantastic sand rail..
There's no "kit" for you, unfortunately.. The whole thing has to be fabricated. Turbocharger size is based upon power level you want out of this thing (an actual power goal). PSI doesn't mean squat until you have some idea of power level and fuel you plan to use.
Give us those specifics and we can go from there.
Who is Mr Robot?
Re: Turbo Sand rail
As TheShodan stated. There isn't a "bolt on" solution for you. Nearly every single part will have to be custom fabricated in a one off fashion
Re: Turbo Sand rail
I want to get a system built for it that will run on high octane pump gas without blowing my motor into pieces, but next year or two I would like to built a motor that can handle a lot more turbo. Friends of mine have different V-6 engines in their rails that I want to do wheelies around. There isn't very many Honda powered sand rails so I want to represent.
Moderator
Re: Turbo Sand rail
Ok. What power level are they at to compete? Since we don't rely know what comparable rails are making in terms of power level and torque, that would be helpful in determining whether or not you need a single turbo, twins, have to build the engine, etc..
if thats your plan, then I suggest buidlding the setup you hope to run on your built engine, onto this engine, but turned down in terms of power to keep it from blowing up. that way when you do get to build the new setup youre not having to buy everything again.
Posted from Honda-tech.com App for Android
Re: Turbo Sand rail
it could be done pretty quick and cheap id say. the tuning is the issue. the 6 I imagine could hold 400HP with the stock internals tuned but you gotta buy a stand alone ecu and tune. break out the wallet and upload some pics tho asap. make sure you face the turbo backwards lol or youll be eating sand. nitrous?
Re: Turbo Sand rail
Re: Turbo Sand rail
The other rails are pretty stock. Right now I run right along with them. Nobody really pulls away from the pack , so I want to be the one that does. I have a Mendeola trans so I can easily run 500 to 600 horse without a problem (future). So let's put together a system that could hit that without a problem. Remember I don't want to have to run avgas. What do you think?
Who is Mr Robot?
Re: Turbo Sand rail
Nitrous on a sand rail is pointless and given the drastic changes in throttle input it greatly increases the chances for things like nitrous backfires and other destructive issues
Re: Turbo Sand rail
Thread to see what the sandrail looks like and what we have to work with here?
I would say something like a 6262, water to air intercooler, and a good solid tuning solution would be a start. What kind of fuel pump do you have on the rail right now?
Also, probably don't have to point this out, but you'll absolutely 100% need a damn good filter on that turbo in that kind of environment.
Moderator
Re: Turbo Sand rail
Well, I guess its just just about anything can fit in there. Its really again, a matter of power level desired and what you're willing to spend for turbochargers. I honestly believe that a twin rear-facing setup would be optimal. I remember helping out a few guys in Arizona with a setup like that, and it was pretty cool with two GT3251Bs in tow. Damn thing made over 500-600hp to boot.
Everything from the intercooler piping to manifolds had to basically be fabricated though. So I guess that's where we're at a loss. there's obviously no "kit" available for this. The question is, do you have the resources that can help fabricate for you? Do you have a preference in cost for the turbochargers? wastegates? How you need it setup?
These are things we can't answer for you, unfortunately, as this will be a truly nice and custom setup.
Who is Mr Robot?
Re: Turbo Sand rail
Well you've basically got a turbo manifold done if you wanted to go single... just cut off the muffler section, add a 90* piece, weld the turbine inlet flange to that and then take the 90 you welded on and add a wastegate flange directly inline with the exhaust flow and there's most of the hard work and biggest expense (next to the turbo and engine management) out of the way
Re: Turbo Sand rail
Shodan, if I built a twin turbo set up, could I run it on this stock motor for a couple of seasons before I am able to build a new motor? I would love to run twins on it. Ha, where do I begin? I do have a fabricator that will work with me on this, but he has no experience with Honda engines or turbos. How much do you think it would/should cost to build this, including turbos, intercooler, wastegates etc?
Who is Mr Robot?
Re: Turbo Sand rail
The j series motors are beefy from the factory
A guy is making 750-800whp on race gas with a single large borg warner turbo a stock j32
You should be fine reliability wise if you keep the power level reasonable and have a really good tuner and consistent fuel blends
Moderator
Re: Turbo Sand rail
No way would I put a large single turbo on there like that.. This isn't some quarter mile race or a single hill climb in 1000 foot sand dune climb in Dubai going for BIG POWWAAA. He's jumping smaller sand dunes all over the place, using the throttle to control power as much, if not more than the steering wheel. He needs instant power to last in the top end. Smaller twins about 50-60 lbs/ min would do that over some large diesel sized turbo
Who is Mr Robot?
Re: Turbo Sand rail
You could size a single with a t3 turbine housing (.82) and a larger turbine wheel along the lines of a p trim and have amazing response
He has enough displacement, we aren't talking about a 1.6 liter motor but a 3.2+ liter v6
Re: Turbo Sand rail
Very true. I do need the quick response for the sand. I am in and out from idle to full throttle constantly, so I think I would like to set up a pair. Now I need recommendations and part numbers. I will start buying everything I need now. Thanks for helping me build this rail.
