Turbo Poorman's R Build Thread
Old 03-14-2008, 05:11 AM
black_EM1's Avatar
Default Turbo Poorman's R Build Thread
Another N/A guy goes to the darkside.
My build:
B16 head
ITR cams
AEBS IM
81.5mm B18C1 block
Eagle rods/CP pistons
ITR crank
PeakBoost Ramhorn Full Kit
GT3076R
3in downpipe, Tial hardware
Random Technologies 3in cat
KTeller 3in/Magnaflow 3in
RC 750cc's
Hondata S300
I put the shortblock together, yes I have pics, they'll be up soon, at a buddy's house 2 weeks ago.
Last weekend, the B16 in my Si breathed it's last breath. Out she came. The head was removed, cleaned and mated to the GSR block. And she will be reborn this weekend. I'll be shooting for 350-400whp@ under 20 psi.
Updates coming soon.
[IMG
[IMG]
Modified by black_EM1 at 5:42 PM 3/16/2008
Old 03-14-2008, 06:06 AM
carzntune's Avatar
Default Re: Turbo Poorman's R Build Thread (black_EM1)
Sounds like a fun streetable setup. Any thought in upgrading the valve springs? I don't see it taking anywhere near 20psi to reach 400 with a 3076R. Which housing option do you have? .63 housing was nice on my original setup which put down 375hp at 11psi.
Old 03-14-2008, 06:20 AM
Armed Ferret's Avatar
Default Re: Turbo Poorman's R Build Thread (carzntune)
+1 on far less than 20psi being needed for 400 on that setup. i'm on my way to a 3076-based build as well, but i'm a bit behind you. just focusing on getting a rolling chassis for now cause i'm PCSing this summer.
good luck, you're gonna have a blast in that thing!
Old 03-16-2008, 06:56 AM
black_EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carzntune &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a fun streetable setup. Any thought in upgrading the valve springs? I don't see it taking anywhere near 20psi to reach 400 with a 3076R. Which housing option do you have? .63 housing was nice on my original setup which put down 375hp at 11psi.</TD></TR></TABLE>
I got the .63 housing as well. And I actually am iffy about using ITR cams on my stock valvetrain, so I orderded some Crower stuff yesterday. I'm safe until 8k for now.
Motor's in, just go to put in the axles/shift linkage/turbo kit today.
So way less than 20 psi is needed? I'm glad to hear that.
Old 03-16-2008, 01:45 PM
JSEF9's Avatar
That thing will spool pretty fast!
Old 03-16-2008, 02:18 PM
SovXietday's Avatar
Default Re: Turbo Poorman's R Build Thread (JSEF9)
Oh snap, Charles in the FI forum. You've talked about it, but I never actually thought I'd see the day.
When you get this done make sure to bring it up. Don't forget, you owe me a good Philly cheesesteak.
Old 03-16-2008, 02:38 PM
JoePSI's Avatar
Default Re: Turbo Poorman's R Build Thread (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
So way less than 20 psi is needed? I'm glad to hear that.</TD></TR></TABLE>
Way less. It only too 14psi for me to hit 380hp (using a log manifold).
Your crower valvetrain is only good for 8K? you should be able to take that to 9k now. I take my 01 itr cams to 9k with a supertech valvetrain, i'm assuming they are comparable.
If this is an unsleeved 9:1 C:R block I would try to keep it under 18psi on pump. you'll definitely hit 400 before that.
Old 03-16-2008, 02:46 PM
black_EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Oh snap, Charles in the FI forum. You've talked about it, but I never actually thought I'd see the day.
When you get this done make sure to bring it up. Don't forget, you owe me a good Philly cheesesteak. </TD></TR></TABLE>
First time for everything. And I'm definately coming up to Philly again.
Update:
Motor is in, and everything is connected. She looks good, but the Hobby Shop on base closed at 5pm. Tomorrow, I'm hooking up the boost/oil pressure gauge, fuel pump, and putting fuids in.
Hopefully she'll start reborn for the first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI &raquo;</TD></TR><TR><TD CLASS="quote">
If this is an unsleeved 9:1 C:R block I would try to keep it under 18psi on pump. you'll definitely hit 400 before that.</TD></TR></TABLE>
I've got stock B16 valvetrain in there now, the Crower stuff's on order. 400whp before 18psi makes me very happy.
Modified by black_EM1 at 7:16 PM 3/16/2008
Old 03-16-2008, 03:26 PM
SovXietday's Avatar
I've got stock B16 valvetrain in there now, the Crower stuff's on order. 400whp before 18psi makes me very happy. </TD></TR></TABLE>
Definitely doable, but it also depends on how well everything flows. I definitely see your setup doing what you want it to do though.
Bring it up here, and we'll go terrorize Philly.
Old 03-16-2008, 08:25 PM
project dc2's Avatar
lets cut the bs..
where'd you get that t shirt ?
Old 03-16-2008, 08:44 PM
dansred2000si's Avatar
NIce build!!!! almost identical to mine but i am doing lsvtec and 30r .82ar
Old 03-17-2008, 04:04 AM
black_EM1's Avatar
Default Re: Turbo Poorman's R Build Thread (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">lets cut the bs..
where'd you get that t shirt ?</TD></TR></TABLE>
Rue 21, a few years ago.
On another note, the Omni 4bar Map Sensor is a great little piece. Bolted up just like stock.
Requisite "finished" engine pic.
Modified by black_EM1 at 4:02 PM 3/17/2008
Old 03-17-2008, 12:13 PM
Simmerman's Avatar
Boost is fun.
I'm just curious why you chose the 30R over the 35R?
What do you plan on your final compression to be on the motor? I rarely see Poorman's under boost.
Old 03-17-2008, 03:05 PM
black_EM1's Avatar
Default Re: Turbo Poorman's R Build Thread (Simmerman)
I chose the 30R because I'd rather have a quick/fast streetcar than a full-out monster. The GT3076R is more than sufficient for what I have planned.
The final compression should be about 9.6:1.
Old 03-17-2008, 03:21 PM
blackeg's Avatar
that motor and turbo setup will make power with its eyes closed. id say you'll crack 400whp with between 15-17psi
Old 03-17-2008, 04:46 PM
Simmerman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">I chose the 30R because I'd rather have a quick/fast streetcar than a full-out monster. The GT3076R is more than sufficient for what I have planned.
The final compression should be about 9.6:1.</TD></TR></TABLE>
Word.
Old 03-17-2008, 08:26 PM
bewstn ex's Avatar
the build looks clean and defiannlty nice, i can see 375hp easy on that beast, but the thing that stuck out the most was a philly cheesteak?!? i havent had one in about 2yrs now, dam marine corps put me over in socal, so all i have is in n out burgers
Old 03-17-2008, 08:35 PM
Redcoupe's Avatar
Yup.
Kyle. This is the turbo you should get. It's the turbo I was going to get but with my manifold, I'm running a basic T3T4 because I'm not planning to ever make that much.
Nice setup and it should be fun.
Old 03-17-2008, 10:29 PM
stevoslav's Avatar
Default Re: Turbo Poorman's R Build Thread (Redcoupe)
Old 03-18-2008, 04:44 AM
blaze the chemi's Avatar
Default Re: Turbo Poorman's R Build Thread (stevoslav)
looks nice. I'm in for results. I'll be boosted again one day. until then...
Old 03-18-2008, 08:45 AM
black_EM1's Avatar
Default Re: Turbo Poorman's R Build Thread (bewstn ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bewstn ex &raquo;</TD></TR><TR><TD CLASS="quote">the build looks clean and defiannlty nice, i can see 375hp easy on that beast, but the thing that stuck out the most was a philly cheesteak?!? i havent had one in about 2yrs now, dam marine corps put me over in socal, so all i have is in n out burgers </TD></TR></TABLE>
Always good for something, the Marine Corps. 6 1/2years strong and loving it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">that motor and turbo setup will make power with its eyes closed. id say you'll crack 400whp with between 15-17psi</TD></TR></TABLE>
That's what I'm hoping for.
Old 03-18-2008, 10:54 AM
B20luda's Avatar
GT3076R is a badass street turbo spools nice, can make 500whp+
You will make 400whp at or under 15psi....watch!!!
Old 03-18-2008, 11:22 AM
JDM_EM1's Avatar
Default Re: Turbo Poorman's R Build Thread (B20luda)
you'll deff make 400hp under 20psi, i had a similar setup but smaller turbo and made it with under 20psi.
Old 03-18-2008, 03:40 PM
WalkerGSR1's Avatar
I also had a 30r .82a/r. Made 420whp and 325wtq on 16psi. 2.0 ls/vtec
Old 03-18-2008, 06:34 PM
Always good for something, the Marine Corps. </TD></TR></TABLE>
2nd that, my brother-in-law is a welder at 29 palms--he's gonna install new rocker panels on my teggy for me in July when he's out on leave.
&lt;--SSgt USAF.
S/F
Quick Reply: Turbo Poorman's R Build Thread
