Turbo people: Help me with this DC2 install
Old 02-24-2004, 10:42 AM
jonyb's Avatar
Default Turbo people: Help me with this DC2 install
Nevermind the duct tape and wire ties, the car is going to the paint shop on Wednesday and I just wanted to make sure everything would mount up right so I can modify it now instead of after having it painted. The head and IM is from an ITR, so the intake pipe is going to have to be changed. Also, I'm not using the extra injectors.
Please look at this and tell me if it's right or I need to change something. Also, the pipe on the right side of the IC is crooked where it connects. Didn't know if this was a concern or not. Thanks
Old 02-24-2004, 10:47 AM
Mase's Avatar
Default Re: Turbo people: Help me with this DC2 install (jonyb)
first of all, why did you hack up all of your radiator support for the jdm conversion?
Secondly, id extend the charge pipe from the turbo to the driver side of the IC
Old 02-24-2004, 10:52 AM
jonyb's Avatar
Default Re: Turbo people: Help me with this DC2 install (Mase)
I hacked it up only because it was bent up real bad. It had nothing to do with the clip swap. JDM Inc sent me a f$#ked up clip that was worthy of a junk yard.
Old 02-24-2004, 10:53 AM
Deluzional's Avatar
The way you installed them are correct, but that crooked pipe on the driver side will not hold during boost. If you have a short stubby pipe lying around i suggest you connect it to your intercooler with the silicone, then connect the charge pipe to that stubby pipe. Easy fix
Old 02-24-2004, 10:54 AM
sporkcrx's Avatar
Default Re: Turbo people: Help me with this DC2 install (Deluzional)
yea the driver side pipe isn't going to work like that.
Old 02-24-2004, 11:02 AM
jonyb's Avatar
Default Re: Turbo people: Help me with this DC2 install (sporkcrx)
Cool. Thanks for the input. I wonder if FMAX would have the piping that I could buy. If not, I could have my future father-in-law (that clipped the car, and built the cage) to make new piping when the motor is dropped in. I'm really just wanting to know if I should cut the inside of the bumper or not. The way it sits now, the bumper hasn't been cut.
Old 02-24-2004, 11:48 AM
JM Performance's Avatar
wonder if that "support" will actually hold the radiator? guessing no...
Old 02-24-2004, 12:23 PM
jonyb's Avatar
Default Re: Turbo people: Help me with this DC2 install (00SilverLS)
You mean the bumper reinforcement? I can have that piece braced up later if it creates a problem.
Old 02-24-2004, 12:30 PM
yellowturbo's Avatar
first of all I would put the engine in the car to be sure that all will clear ...
Old 02-24-2004, 12:56 PM
ProEater's Avatar
Default Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">first of all I would put the engine in the car to be sure that all will clear ... </TD></TR></TABLE>
haha it sounds dumb but you wont know for sure until its in
Old 02-24-2004, 01:17 PM
Moderator in Chief
Muckman's Avatar
Heres how mine looks on a USDM front end.
Your IC pipes can come out alot further on the sides. They should come out even and parrellel from the FMIC ends and just wrap around the shell in front of the wheel.
Old 02-24-2004, 01:19 PM
boosted_dc2's Avatar
Default Re: (ProEater)
a 45 degree coupler would probably work on that driver side.
Landon
Old 02-24-2004, 03:18 PM
g5r
g5r's Avatar
i have to cut the bumper up a bit for my ic to fit the jdm bumper. My ic is 3.5 inch thick though.
blah11
Paint and Body
03-16-2008 03:10 PM
GiNuWiNe
01-05-2007 12:29 PM
loopedR6
10-13-2006 09:20 PM
VTC_CiViC
08-04-2003 07:14 AM
Quick Reply: Turbo people: Help me with this DC2 install
