turbo manifold need opinion
Re: (Snafubmx234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 »</TD></TR><TR><TD CLASS="quote">Probably. </TD></TR></TABLE>
Re: turbo manifold need opinion (b18sihatch)
It's obviously not ideal placement, but depending on how much boost you run you might not have any problems.
I ran a Drag manifold on my last setup (worlds worst WG placement) and I never had any issues with creeping or spiking. So who knows.
Re: turbo manifold need opinion (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">It's obviously not ideal placement, but depending on how much boost you run you might not have any problems.
I ran a Drag manifold on my last setup (worlds worst WG placement) and I never had any issues with creeping or spiking. So who knows. </TD></TR></TABLE>
A friend of mine ran a drag manifold, crappy wastegate placement just like the OP's manifold. Manifold held 15psi before creeping. So if you run 12psi or less I would say you should be fine.
Location: What Business is it of yours where Im from Friendo
Re: turbo manifold need opinion (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">tip of the day : that is the number 4 runner.</TD></TR></TABLE>
Haha...I noticed that and I thought I was going crazy for a minute there. Poor placement for sure, and the likelyhood for holding solid boost is comprimised greatly.
Re: turbo manifold need opinion (b00stME)
thanks for the reply, this is going on my stock ls motor running a t3 60ar hot/48ar compressor not sure what the trim are, also have a 38mm tial wastegate for it. looking to make around 250-300whp
Modified by b00stME at 3:41 AM 2/27/2007
jdm_kenji
07-23-2003 03:14 PM
