turbo manifold and dip stick
I have seen some turbo manifold where it covers the dip stick or block it. I notice this on the lovefabs sst and full race's. WHat do you guy do to check oil level?
Re: turbo manifold and dip stick (doubler)
I do oil changes every few days https://honda-tech.com/forums/images...s/emsmilep.gif http://images.honda-tech.com/set1//smile/emcrook.gif
if the dipstick is close to clearing the runners you can bend it. I had to bend mine maybe 1/2" to fit between my revhard mani.
Re: turbo manifold and dip stick (Muckman)
just a lil bend up in the dipstick and it clears the full-race manifold.
Re: turbo manifold and dip stick (c jackson)
Re: turbo manifold and dip stick (pissedoffsol)
Looks like it would melt the handle https://honda-tech.com/forums/images...s/emsmilep.gif
Is there an aftermarket dip stick that has a longer handle than the OEM one? |
Re: turbo manifold and dip stick (BG Boost)
your gunna want to take that rubber deal off of the dipstick, it will just burn away and make somethin messy.
i took a torch to mine heated it up redhot and bent it.
worked well. then ground the end so it would slide in bettter! https://honda-tech.com/forums/images/smilies/emthup.gif |
just mucled mine a bit and bent it to fit.
Re: turbo manifold and dip stick (shortyz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz »</TD></TR><TR><TD CLASS="quote">i took a torch to mine heated it up redhot and bent it.
worked well. then ground the end so it would slide in bettter! https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> you had to heat up the dip stick to bend it? it's almost as small as a wire coathanger https://honda-tech.com/forums/images...es/emdgust.gif |
Re: turbo manifold and dip stick (Bailhatch)
he is talking about the dipstick tube.
Rob |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">your gunna want to take that rubber deal off of the dipstick, it will just burn away and make somethin messy. </TD></TR></TABLE>
even though it looks like it- its not touching the manifold at all... |
worked well. then ground the end so it would slide in bettter! https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> haha, weak sauce https://honda-tech.com/forums/images/smilies/emwink.gif |
