turbo is leaking oil
so now it seems that the turbo is leaking oil on the exhaust side were it rotates to fit properly....i checked the bolts and one needed half a turn if that if it continues to leak does that mean the turbo is messed up?
Re: turbo is leaking oil
your seals are gone. the bolts dont really tighten anything that has to do with your oil seals except making sure your turbine housing is on correctly and centered
ahh, well thats a bonus of dealing with a good company. It sucks to have to do the work and wait, but at least it will probably turn out allright.
got my turbo back most of it is back in rewiring gauges and sensors... yet i gotta do something about my turbo drain...
they fixed the journal bearing for b/b shaft turbine end and then gapless trubine end piston....why would those things go bad? oil not draining? too much oil feeding the turbo?
it means my **** better work lol.....its a metal sleeve that the shaft rotates in oil goes through it to lubricate aswell
