TURBO INSTALL!!!!! need anwsers....ben? anyone?
Ok, well i finally got my turbo and started to install it yesterday.....one problem/issue i have run into is the following:
the stock cat has a secondary heat oxygen sensor (obdII), i have a 3" car sound cat waiting to go in, howeer this new cat does not have a place for that sensor, waht do i do??????????????
Re: TURBO INSTALL!!!!! need anwsers....ben? anyone? (Slow_ass_4dr)
Get your new cat....Drill a hole it in about the size of that new O2 bung that Slow told you to get and weld it on there.
Re: TURBO INSTALL!!!!! need anwsers....ben? anyone? (Blown90hatcH)
Make an appointe and take your car to your muffler shop after you're done with the install. They will finish up the exhaust system for you.
Re: TURBO INSTALL!!!!! need anwsers....ben? anyone? (ben@importparts.com)
sweet, thanks fellas! so all i have to do is bring the cat and have them weld in a bung for that O2 sensor
so far the install is going great! thanks for the help, i knew i could count on you guys!
jomama
12-09-2007 02:39 PM
SantaCruz92Si
01-27-2005 08:45 PM
