TURBO INSTALL GOING SHITTY! need help need someone know knows turbos
Old 08-18-2003, 09:23 PM
racinskittle's Avatar
Default TURBO INSTALL GOING SHITTY! need help need someone know knows turbos
Well im putting this ******* T3 tyurbo on my D16z6 del sol si, and EVERYTHING is in the way. I tried switching sides and no luck! There is one VERY easy way to solve my problems but I dont know if I can do it.
The outlet on the compressor housing shoots straight into the block. Is it ok to take the housing off, and spin it 180 degrees around so the outlet shoots to the front? Please say yes (this will solve all my problems lol.) otherwise this week is going to be HELL
Old 08-18-2003, 09:26 PM
johnisenglish's Avatar
Default Re: TURBO INSTALL GOING SHITTY! need help need someone know knows turbos (racinskittle)
Yes, clocking the turbo is perfectly fine. Just loosen the 6 bolts holding either housing on and rotate as needed. Make sure that the oil return outlet is facing straight down, and you'll be set.
Old 08-18-2003, 09:27 PM
sporkcrx's Avatar
External or internal wastegate? If it's external you can clock the turbo to however you want. You're limited w/ an internal wastegate unless you get savvy and start custom mounting it.
edit: god dammit, 1 min late!
Old 08-18-2003, 09:28 PM
Default Re: TURBO INSTALL GOING SHITTY! need help need someone know knows turbos (johnisenglish)
HOLY ****! SWEET THANKS!
I was gettin friggin worried
Old 08-18-2003, 09:29 PM
lol it's internat but im prolly gonna custom mount that anyways
But hey better late than never
Old 08-18-2003, 09:40 PM
Will it work if the drain is sideways? My educated guess is no
Old 08-18-2003, 09:42 PM
sporkcrx's Avatar
Your educated guess is correct!
Old 08-18-2003, 09:43 PM
Brrraaaap!
Blaze45's Avatar
If your drain isnt facing down, gravity will have a hard time pulling the oil out... and you can blow your seals on your turbo...
Blaze
Old 08-18-2003, 09:47 PM
Default Re: TURBO INSTALL GOING SHITTY! need help need someone know knows turbos (Blaze45)
ok thanks. luckily this happened, i wouldn't have clocked it if it didn't. (drain was sideways)
Old 08-19-2003, 04:14 AM
Happyman's Avatar
I'm installing the greddy kit on my del sol si. I hate oil pan gaskets. thats what's holding me up ;[. farggin ****.
JDMeg95
12-12-2007 12:40 AM
radioren
08-13-2005 07:38 AM
ITSTOCK
03-20-2004 12:22 PM
TurbothisLS
09-26-2002 07:58 AM
95 LS
04-16-2002 05:18 AM
Quick Reply: TURBO INSTALL GOING SHITTY! need help need someone know knows turbos
