The turbo goes on in 2 wks, which exhaust would be best?
I have a Comptech now but it is kinda small. I was thinking about the Apexi N1 and the Thermal. Any ideas on the matter or should I just keep my exhaust and spend the money else where. I like the Comptech because it looks factory, but could use some opinions.
Re: The turbo goes on in 2 wks, which exhaust would be best? (00 turbosi)
I had my car dynoed running seven pounds of boost with a Greddy Power Extreme vs. no exhaust, and there was a twenty whp difference. Get a three inch thermal and a test pipe.
Im not voting cause i dont have one, but just to throw it into the mix, what about a Custom exhaust. Nice 3" and get a thermal muffler, or some other muffler...quieter perhasp http://images.zeroforum.com/smile/emsmile.gif
[Modified by Ricehornet, 12:07 AM 6/18/2001] |
Re: The turbo goes on in 2 wks, which exhaust would be best? (Ricehornet)
why dont you give the greddy evolution a try? it has a 70mm muffler i think it might flow better than the N1
Re: The turbo goes on in 2 wks, which exhaust would be best? (BowSeR)
what size is the piping on the evolution
I believe ALL japanese exhausts made are 60mm. Except for Thermal 3" of course.
Greddy Evolution is 70mm only by the muffler. The piping is still 60mm. http://images.zeroforum.com/smile/emsad.gif If you want maximum flow then get thermal 3". |
Re: The turbo goes on in 2 wks, which exhaust would be best? (TurboIntegra)
its a 60mm to a 70mm muffler
i gained 49hp's and 26tq @ 7psi on my drag3 setup by switching to the thermal 3" from the stock.
the thermal is VERY loud. i cant emphasize that enough. go listen to one if you can before buying. |
