turbo eg question
I have a 4dr Eg with a SOHC ZC non-VTEC. Currently i'm running the Greddy turbo kit with the TD04 turbo. I'm running 5psi. I was wondering how much boost can the stock SOHC ZC handle. Everything is stock and i'm running an FMU.
**Edited** |
First off all, you cannot base an engine's output/ power capacity in terms of psi. Power created per psi varies with the turbo and engine setup. On a stock D series, the general "safe" range is 220-240whp with a good tune. Since you're running the FMU which is far from a good tune, i wouldnt attempt more than about 200whp if you want it to last. I would suggest getting a real EMS like Crome on a chipped P28, then tuning.
Re: (Schister66)
Schister knows all https://honda-tech.com/forums/images/smilies/emwink.gif
Re: (RCautoworks)
but isnt the p28 for vtec. i dont have vtec. http://images.honda-tech.com/set1//smile/emcrook.gif
Re: (tersaydeez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tersaydeez »</TD></TR><TR><TD CLASS="quote">but isnt the p28 for vtec. i dont have vtec. http://images.honda-tech.com/set1//smile/emcrook.gif </TD></TR></TABLE>
you can turn it off with some sort of ems installed |
