Turbo Coolant Lines on H22A
hey guys,
how are you H Series guys running you coolant lines to and from your turbos?
i know the b series guys use the freeze plug on the front of the block and also tap the radiator. . . what are the H series guys doing?
pics and info would be appreciated
Re: Turbo Coolant Lines on H22A
On the back of the block there should be a rubber hose that connects the the water pipe. You can T into that and use it as the feed. Then just use the top of the radiator as the return.
are you referring to the rubber hose that goes from the water pipe to the oem oil cooler under the oil filter?
on another note . . .
does anyone know if the drain plug that the b series guys use for the coolant feed thats on the front of the block near the engine stamp is just on the back of the block near the water pipe on a H series?
if so, is it the same thread as the b series plug?
then if its the same couldn't i use this plug in much the same way as the b series guys? all i'll need is a bit more line.
any boosted h series guys feel free to chime in
morgan@synapse motorsport
07-06-2010 06:39 PM
JCracer723
01-05-2007 08:26 PM
EK45VTi
04-22-2004 08:16 AM
