Turbo charging my b18a1
#26
Re: Turbo charging my b18a1
well its going to be just a track car since i already been state reffed here in cali for smog and it was either go stock or take it off the street so off the street she went after single cam turbo. on thursday the cars going to a shop to help me with my radiator and wastegate clearance issues and review my vacuum lines. i also want to know if anyone knows if i should ditch the stock a1 mani and get a blox or skunk with a obd1 tb?
#27
ok so heres my setupe. i have a t4 borg warner s200 with 56mm compressor so the s256, aem fuel pressure requlator, walbro 225 lph fuel pump, 2ng gen dsm 450cc injectors, uknown t4 top mount exhaust manifold with dual vband wastegate ports(ones blocked), Aem Adjustable cam gears. I still need advice on if i should get like a blox intake mani and a obd1 tb or should i cough up the cash and get a skunk 2 tb as well and what kind of wastegate is short and vband. i was thinking of a wyntonm soirt compact 10psi wastegate but its cheap.? ive been trying to piece this darn car together for 2 years now i used to have a single cam turbo in it but now its b18a1.
#28
I'm planing on boosting my my 91 ls it has 218 k on the motor my plan is to buy a ebay Turbo kit for less than 600 bucks use a missing link and boost dependent fmu and run about 6 to 8 psi and retard my timing to 12 my goal is 240 to 260 up with stock injectors then upgrade engine Turbo and injectors later on did a leak test fixed a couple small oil leaks and put new water pump timing belt and thermostat in it compression checks out at 188-190 across the board at 6 cranks so what you guys think of my plan and are my goals possible with this set up
