Turbo Charged b18c6 not starting
Hey guys
My car is not starting!! B18c6 (OBD2) was working fine one nite after driving it, next morning i come to start and its just not happaning.
The things ive managed to distinguish!
Main Fuel Relay is fine, !
pumping fuel through fine!
Checked all fuses, etc no issues there.
Timing belt is fine
Now ive purchased two dizzys, one that i know was working fine and one that i was told is working fine but there is NO SPARK!!
Im worried that some how when i plug up a new dizzy its is blowing it some how, but not sure what may be letting thing this happen ?
The car is trying to start but as said no spark.
What i did try and found a bit bizarre was, after bolting up the dizzy initially and getting no spark. i went ahead and un-bolted it, and turning the dizzy manually with my hand, i can hear it click, but its not continious click there seems to be a delay and then a clicks again.
Unlike other dizzys ive tried like tht in the past there is a constant click when turning the dizzy but with this there seems to be a delay.
No engine check light
so still a car thats not starting, any help more then welcome!!
Thanks
Timing belt is fine
Thanks
Re: (mikkey1)
You will want to move this to another subforum (like Tech/Misc). Your problem really has nothing to do with Forced Induction...unless an ebay electric supercharger is sapping all the electricity.
I don't know about the clicks. AFAIK all the internal sensors are solid-state. The only mechanical action is the rotor spinning & almost touching the cap. If both dizzies don't work, your issue is elsewhere - maybe the ECU.
Jump the Service Connector, if you don't get blinks or a solid light on the CEL, it likely is your ecu. There have also been cases where circuits on it are fried w/o tossing a code.
mikkey1
09-03-2008 11:46 AM
