TURBO TO big for my SOHC???
Re: TURBO TO big for my SOHC??? (fc3srx729)
well its not a honda but 8v sohc none the less on my 8v 2.0 with 10:1 stock comp, with a 48 hotside 60 trim E compressor i get full boost at 3500
Re: (ELSpool)
that sounds i little big i have a t3/t4 60 trim with a .63 hotside a .60 compressor and a stage 3 wheel on a b18b and it doesn't spool until 5000 rpm. so you might want to go slightly smaller.
Re: TURBO TO big for my SOHC??? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">that sounds like fun to me one of my manifolds will help spool-up </TD></TR></TABLE>
Exactly what my T3/T04E 50 trim .63a/r will be doin. Matin with a lovefab mani
Re: (blueturboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueturboteg »</TD></TR><TR><TD CLASS="quote">that sounds i little big i have a t3/t4 60 trim with a .63 hotside a .60 compressor and a stage 3 wheel on a b18b and it doesn't spool until 5000 rpm. so you might want to go slightly smaller. </TD></TR></TABLE>
Try opening up your exhaust a bit. That's a lot of lag. I had the same turbo matched to my B18B and it spooled at 2000RPM.
Re: (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com »</TD></TR><TR><TD CLASS="quote">That's actually a good turbo for 2.3L.</TD></TR></TABLE>
Try opening up your exhaust a bit. That's a lot of lag. I had the same turbo matched to my B18B and it spooled at 2000RPM.</TD></TR></TABLE>
It really isn't that much lag at all. My car screams and I have the same turbo although with a 60 trim. Here is my setup if you are curious.
https://honda-tech.com/zerothread?id=520599
I am also going to be putting in a built motor in the next month too which is why I went with this turbo.
what manifold did you have?
my drag manifold with the 57 trimm .60 .63 fullboost at 4.5-5ish
Re: (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 »</TD></TR><TR><TD CLASS="quote">
my drag manifold with the 57 trimm .60 .63 fullboost at 4.5-5ish</TD></TR></TABLE>
It was a DRAG manifold. We're talking spool up here but mine hit full boost around 5000rpm too.
It was a DRAG manifold. We're talking spool up here but mine hit full boost around 5000rpm too.</TD></TR></TABLE>
my mistake then i meant hits full boost at 5000 rpm.
Tippyman
01-01-2007 05:56 PM
trooper0641
08-22-2005 06:55 AM
