TURBO FOR B20/VTEC STOCK BOTTOM END?
I'm looking for suggestion on which turbo to use on my b20/vtec motor. Its for street use, stock bottom end, and will using 10psi of boost. I'm looking for great power to 8000 rpm, but at the same time seeing full boost no later than 4000rpm. I'm looking for 350hp. My thoughts are between a Turbonetics T3 SUPER 60, Garrett GT3071, OR the new GT-K 350 from Turbonetics. Any suggestions greatly appreciated...Please reply only if you have experience with any of these turbos.
Modified by spooledb20 at 11:12 AM 9/3/2008
the t3 super 60 is like buying a no-name brand cereal from the dollar store, and the GT3071 and GT-K series are like buying the name brand from a good grocery store.
GT-K's aren't widely used but are a great turbo design, I personally would rock one if I had the change layin around.
Problem is, your goals don't mention hp anywhere. Don't even think psi until you name your horsepower goal, then determine what boost you need to run to get that goal.
either the 3071R or GTK350 will make 350whp pretty easily. A 3076R will make more power obviously, but spool with be a minute bit later.
Re: (chimmike)
you should get tight with reggie from turbonetics. Craig(my350zclubofflorida) got one for free i think. he gets everything free from them lol.
clemsonteg
11-13-2016 05:44 AM
