turbo 91 civic
turbo 91 civic
a buddy of mine has a 91 civic wit a 91 b18a and a turbo. we got the car running and it idels good untell u try to drive it . it starts to putter . dose any one have a clue y it is doin this and how we can fix it ? thanks
Re: turbo 91 civic (killer91civic)
its going to be a vacum hose, check the ones by the throttle bodies and the ones that go to the map sensors check for cracked or holes on the hoses
Re: (ImportHatch)
It he's using bigger injectors with an ecu that still thinks they are stock 240's, it will run like ****, if at all.
Try to give us more info, unless uselessly short responses like "it's your timing" are what you're looking for.
Re: (killer91civic)
He talking about my car its a
91 civic ex 4dr
t3/t4 turbo
91 b18a1 (ls trans)
equal length manifold
turbonetics wastegate (7 psi)
ngk spark plugs 30 gap
2 1/2 dp
eclipse bov
eclipse 440 injectors
turboedit ecu
91 civic ex 4dr
t3/t4 turbo
91 b18a1 (ls trans)
2 1/2 dp
eclipse bov
turboedit ecu
Re: (4DRCIVICB18A)
Did you install all the wireing yourself? Try and check the TPS clip and MAP clips on the TB. They are the same type of clips on the harness and you might have them switched and this can cause the sputtering/no power.
Re: (Redwidow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow »</TD></TR><TR><TD CLASS="quote">Did you install all the wireing yourself? Try and check the TPS clip and MAP clips on the TB. They are the same type of clips on the harness and you might have them switched and this can cause the sputtering/no power. </TD></TR></TABLE>
yes damn good advice. ive seen this happen to a few cars, and its a very easy mistake to make
Re: (blackeg)
That and drop the spark plug gap down .30 isnt gonna work to well at 7 psi .. my single cam turbo is set down to .22 at 8 psi. For another EF .. best of luck
Re: (killer91civic)
I'm going to guess that by saying "it ran good before the turbo", you mean that it was fine before changing anything. If you added the injectors, ecu, etc and it ran, then I can't help much beyond what is already posted.
If you just jammed all the parts on at once before checking parts individually with it N/A, then I'd say do so. Back up, take the parts off, then put them on one at a time (mainly the injectors). Also, try the stock 240cc injectors again (but DON'T BOOST WITH THEM!!) and see if that is the prob or not. Flooding the cylinders with gas can create symptoms you are seeing. Double check the turboedit tune. There's absolutely NO WAY that anyone could possible create perfect ign/fuel maps for your car w/o physically being there to tune it, so the ign/fuel maps might be the problem too. One thing to understand is that any turbo setup can essentially be run w/o a turbo present, since most cruising is done w/o boost present. Hence installing each part individually and checking that it works.
