Turbine Exhaust Studs??? Bolts Wont Clear DP - Can I stud it?
I want a CRX tattoed on my butt
I just made my 3" d/p setup and I had to make such a tight radius bend right away that my downpipe is to close to the flange where it turns and I cannot place the bolts through the holes, there is a good 1/2" clearance so i know if I could find a stud (whatever thread and pitch these bolts are) that I could clear a nut no problem
Is there any problems with running a stud on the exhaust housing? Or will it spin out?
Re: Turbine Exhaust Studs??? Bolts Wont Clear DP - Can I stud it? (TurblowEF)
i thought a stud was the preferred method anyways. i cannot think of any reason why you shouldnt use a stud.
Re: Turbine Exhaust Studs??? Bolts Wont Clear DP - Can I stud it? (ham)
Oh sweet that good then
Hopefully I can acutally find one of these *******
I use 4 studs on my 5 bolt flange, due to the tight turns of the 3"... Throw a lock washer on there and you'll be golden
Re: Turbine Exhaust Studs??? Bolts Wont Clear DP - Can I stud it? (2muchPSI)
M8 X 1.5 right?
How do I get them in? Do they have 2 flats on them?
Re: (Boilermaker1)
so how long should they be in total? Im glad I couldnt fid any when I was out, tried autozone and home hardware
Think home depot would have them? I doubt it
sleepencivic
03-22-2011 06:39 PM
ringgold
12-09-2005 11:20 AM
