Tunerview II DIY install, pics, details, check it out!!!
Old 10-24-2008, 06:53 PM
E-thug
boostismycrack's Avatar
Default Tunerview II DIY install, pics, details, check it out!!!
I will start this thread by saying this install is pretty simple, but you must have some tools, mechanical inclination and computer knowledge. Start by unpacking all of the box contents. Download the latest tunerview II software from hrtuning.com. Plug the tunerview II into your computer with the provided usb cable. Select your ecu, pick your engine parameters and sensors, then program the unit. Once the unit is programmed, (see hrtuning.com) everything else is done in the car. This particular DIY is for EG civics (more custom kits to come...).
Step 1. Remove the radio or a/c controls. (This particular unit will replace the radio)
Step 2. Draw a line on the bottom of the tunerview with a marker about 1/16th of an inch at the bottom.
Step 3. Using a belt sander (yes I said belt sander) sand the line off of the board.
Step 4. Insert the unit into the radio opening and line up the LCD with the trim bezel.
Step 5. Once aligned, drill small holes (I used 7/64 bit) in the plastic where the tunerview holes line up. Only 3 out of 4 holes will line up. Also plug the provided CN2 plug into the unit. (Harness location will vary depending on ECU, see hrtuning.com for details)
Step 6. Use the provided nuts and bolts to mount the unit. Use the nut on the top left hole as a spacer like this.
Step 7. Screw the remaining bolts into the plastic and reach around the back and secure them with the provided nuts.
Step 8. Apply double sided tape to the top and bottom of the LCD to mount the trim bezel.
Step 9. Peel the film from double sided tape off, mount the 2 switches through the trim bezel and secure it to the LCD like this.
Step 10. If you have neptune/ectune plug the other side of the CN2 harness into your ECU and enjoy! If you have S300/K-PRO plug the other side of the CN2 harness into the provided USB module. Then plug your USB cable from your ECU into it. The green wire from the module MUST go to swithced TRUE IGNITION and the white wire to ground.
Everything you need to install this in your EG is available including the trim bezels! Hope you guys enjoy!
Modified by boostismycrack at 4:03 AM 10/25/2008
Old 10-24-2008, 07:19 PM
HighRevn's Avatar
Default Re: Tunerview II DIY install, pics, details, check it out!!! (boostismycrack)
Looks badass, good job
Old 10-24-2008, 07:25 PM
hatchboy's Avatar
Outstanding write-up! I don't even have a EG but i still enjoy'd the write-up.
Old 10-24-2008, 07:32 PM
E-thug
Default Re: (hatchboy)
Thanks! Kits for other models will be available soon!
Old 10-24-2008, 08:49 PM
HT White Ops
SD_Lurker's Avatar
Default Re: (boostismycrack)
Looks good young man!! Luckily I have a 96-98 hatch where I can put the radio down below and tunerview in the actual radio section. Do you plan to do one in a 96-00 civic in the coming weeks? I will figure something out its pretty much the same thing as yours but seeing it first would be nice!
Old 10-24-2008, 08:56 PM
E-thug
Default Re: (SD_Lurker)
Yes, ek civic and dc integra will be next. I need a donor car for the 96-98 though...
Old 10-24-2008, 09:00 PM
88ED8's Avatar
Old 10-24-2008, 10:16 PM
hatchboy's Avatar
Wonder how much different the casing for the EG is than the EF.
Old 10-24-2008, 10:25 PM
HT White Ops
SD_Lurker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Wonder how much different the casing for the EG is than the EF.</TD></TR></TABLE>
If its not exact its pretty darn close since CD players are universal unless double dins.
Old 10-25-2008, 12:16 AM
hatchboy's Avatar
Well mabey i need to order my mfactory lsd and this here pretty quick
Old 10-25-2008, 08:47 AM
HRTuning's Avatar
I see you're enjoying the product. Nice writeup and man that Carbon Fiber looks good!
Old 10-25-2008, 09:43 AM
ghostofnyc's Avatar
nice
Old 10-25-2008, 11:43 AM
I.C.C.'s Avatar
looks great... i may have to pick one of these gadgets up once i actually get my car up and running again.... good stuff
Old 10-25-2008, 11:48 AM
captamericao9's Avatar
nice write up
Old 10-25-2008, 04:36 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
good write up eric, give people the confidence to do it themselves.
Old 10-25-2008, 04:51 PM
norconex's Avatar
Default Re: (HybridcivicLS-T)
Nice write-up
Old 10-25-2008, 06:09 PM
E-thug
Default Re: (norconex)
Thanks guys. With the pre made trim bezels, this install really is easy. I had more trouble with programming it, than installing it. I am not very good with computers tho...
Old 10-25-2008, 06:12 PM
miguel329's Avatar
nice write up
Old 10-26-2008, 08:45 AM
mrlegoman's Avatar
nice!
Old 10-26-2008, 08:49 AM
HRTuning's Avatar
Default Re: Tunerview II DIY install, pics, details, check it out!!! (mrlegoman)
Video of this same install location
Old 10-26-2008, 09:06 AM
stiffdogg06's Avatar
Default Re: Tunerview II DIY install, pics, details, check it out!!! (HRTuning)
Can't wait for the other write ups. Especially the EK, since I will getting mine soon for my car.
Old 10-26-2008, 01:06 PM
HT White Ops
SD_Lurker's Avatar
Default Re: Tunerview II DIY install, pics, details, check it out!!! (stiffdogg06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stiffdogg06 &raquo;</TD></TR><TR><TD CLASS="quote">Can't wait for the other write ups. Especially the EK, since I will getting mine soon for my car.</TD></TR></TABLE>
EK's are easy. If you have 96-98 put the radio down below and the Tunerview up top where the radio's original location was. Pretty much the same thing he did in his EG. 99-00 would be a little trickier.
Old 10-26-2008, 07:27 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default Re: Tunerview II DIY install, pics, details, check it out!!! (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">
EK's are easy. If you have 96-98 put the radio down below and the Tunerview up top where the radio's original location was. Pretty much the same thing he did in his EG. 99-00 would be a little trickier.</TD></TR></TABLE>
true.
and the 99 would be hard as well. abs plastic and cut it out local radio place could do that
Old 10-26-2008, 07:35 PM
E-thug
Default Re: Tunerview II DIY install, pics, details, check it out!!! (HybridcivicLS-T)
I will be making kits for these soon...
Old 10-26-2008, 09:06 PM
96 GSR-T's Avatar
Quick Reply: Tunerview II DIY install, pics, details, check it out!!!
