Tubular iron manifold material?
Re: Tubular iron manifold material? (Mochanic)
If you are referring to 40 schedule butt-weld pipe, go to your local plumbing shop.
The stuff is superior to mandrel-bent mild steel if you have the equipment to weld it, because it is both thicker and has tighter bends.
Re: Tubular iron manifold material? (beepy)
exactly!!!
I wasnt sure if thats what that was, but I figured it was. Do you know what the technical plumbing name is? Its cast iron right?
Thats exactly what I'm getting ready to build a set of custom turbo mannys out of for my 1000whp 383 LT1
Yes, I have a Z28... yes, I build 10 sec. imports... yes, I know I know...
thanks for the info!
Randy
Modified by Mochanic at 2:56 AM 3/15/2004
Randy
hondafanatic1
01-19-2004 11:27 AM
