trying to get plugs out of block for catch can set up
I am trying to make my catch can set up, but I cant get the plugs out of the block. The engines in the car and its kinda tight, I have the correct allen wrench, but they just wont turn.
any ideas
any ideas
Re: trying to get plugs out of block for catch can set up (jtracing919)
breaker bar or something to provide more/better leverage on the ratchet. But of course be careful not to strip/break anything. And remember, take pictures of the setup/everything when youre done...
Its was very easy for me when I was doing a intake manifold swap at the same time...So if you dont wanna take that off I suggest going underneath the car and remove the oil filter cause one plug is right next to it.Also remove the stock black box and everything connected to it so you have room to work with underneath.
With the intake manifold off its ALOT easier, or the motor out of the car.
Its a 14mm allen wrench, if you can find a Snap on socket with the Allen wrench on it, much easier too.
Goodluck, mine were a bitch the first time around.
Re: (Mr. Helsinki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki »</TD></TR><TR><TD CLASS="quote">I just stuck my floorjack handle onto the allen wrench and manhandled that bitch. No problem.</TD></TR></TABLE>
hahah that's the spirit
ill do this soon, maybe see if i can rig up a 14mm bolt that i can grab onto the threaded end with the head in the block plug
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
ill do this soon, maybe see if i can rig up a 14mm bolt that i can grab onto the threaded end with the head in the block plug</TD></TR></TABLE>
put 2 nuts on the end of the 14mm bolt, tighten them together, then use a wrench on the inner nut (between head of bolt and last nut).
Re: (tegasaurus)
i took my intake manifold off, made it alot easier, i was stripping the walls from trying to do it underneither the car, so i said forget it, im taking the intake mani out, and with a good breaker bar, they came right out, good thing i took it out, i looked at one of the plugs, it held barely enough to break them loose, walls were stripping pretty bad, good luck
vanny_david
07-14-2009 03:25 PM
vinuneuro
06-04-2007 09:03 PM
A.E Motoring
07-02-2006 10:51 AM
