Troubleshooting: Not sure where to go. LS/VTEC Turbo uknown diagnosis
Hi guys, I have a 2010 build ls/vtec, piston rod combo, tuned on crome pro. Never had a big problem till a few weeks, when i try to make a roll in 3rd and it fall on his face ,from the hole it work normal.
check compression 195-200 all over
Buy a good know OE distributor
New wire harness
Timing, wires and plugs
Fresh upload program
Next on the list is send the map to omni and replace the $5 dollar TPS.
Any help
thanks
New wire harness
Any help
thanks
Re: Troubleshooting: Not sure where to go. LS/VTEC Turbo uknown diagnosis
When the car hit full boost start to bog, like boost cut. Try to lower the boost to 14 psi and the same bog happens. Any additional info info. let me know.
Thanks
Thanks
I'm using 93 gas, the plugs are new at .24
I can't datalog, i have all the equipment but not laptop with old windows or crome program/permission, just an old desktop with crome.
carlos8
04-07-2017 08:20 AM
pynikal
19
10-26-2007 12:16 PM
