Troubleshooting: Engine Load "2 step" problems!
Have a boosted b20 fired it up after engine swap and revved it without axles in to try and engage two step now when I drive the car under load when I hit 4200rpm the car goes into lwgat I would describe as two step. Any help is greatly appreciated.
re: Troubleshooting: Engine Load "2 step" problems!
turn off the two step and see if your 4200rpm rev limit no longer exists.
Originally Posted by JRCivic1
(Post 51877466)
Like the others said, disable the two step. If that remedies the problem your speed sensor is probably going out/disconnected/etc.
