Troubleshooting B18C1 Turbo has idling problems with current setup *SOLVED*
Can’t get my b18c1 turbo build to run.
It has sat 2 whole years in my garage while I was away for work. I had it idling perfect last week, turned it on and off multiple times that day. As soon as I tried to back it down the driveway in reverse, it died and won’t idle anymore. It will idle with throttle given, but pops and bangs and puffs smoke. Quick breakdown: Wiseco/Eagle bottom end Edelbrock victorX intake manifold Rc1000’s Walbro 255 Hondata s300 Hondata 4bar Map Unsure what turbo it is. I’ve done 2 compression checks. All cylinders in the 190’s. Done 2 leak down tests. No issues I am getting fuel at the fuel rail, no problems there. Fuel has been drained and replaced with 91 octane. Spark plugs replaced (yes I am getting spark I have checked that) What could it be? Injectors? Bad MAP sensor? When the car is trying to idle (with throttle applied and very poorly, when I remove the MAP from the Intake manifold it continues to run the same no changes). Maybe it’s the MAP? Its strange that it idled so well multiple times in a day then the time I go to drive it, dies. Next step is downloading Hondata to a laptop and plugging it in, that may give me more clues. No engine codes/lights on the dash. Thanks guys. It’s been years since I’ve been on here since I did a d16 vitara turbo build and an h22 ej1 build. |
re: Troubleshooting B18C1 Turbo has idling problems with current setup *SOLVED*
It sounds like by the end of the driveway it was warming up , and thus fell out of tune.
Are you tuning it? With what settings? upload a Datalog or base map . How were you planning on tuning it ? No laptop , or dataloging. There is a procedure for checking the MAP sensor, do it if suspect. |
I'm suspecting fuel or tune related. No cel=no sensor problem. Check map settings and TPS calibration in Hondata, hell, try loading a base map to see if it works out. Sitting for that long takes its toll.
I was also thinking fuel. I know you verified fuel at the rail, but what about fuel pressure? Verify all 4 injectors are firing.
Originally Posted by DaX
(Post 51921945)
I replaced the 4bar MAP with a brand new one that we borrowed and it runs great. Thanks for the input guys.
Thanks for replying with the solution
