Troubleshooting: B16 turbo has low boost pressure after installation & tuning.Causes?
#26
Re: Troubleshooting: B16 turbo has low boost pressure after installation & tuning.Cau
I know big numbers can be made with small turbine housing big turbine wheel combo it happens to be what i like actualy.
A custom s200/300 combo we did here on a subaru with ~60 a/r turbine housing with the schwitzer 65mm turbine wheel and 7+7 64mm compressor hit like 750whp on race gas
I made a speculation about a china/immitation .48 housing not .63.
.48/bad design housing on gt35 would flow around 20lbs/min or less.
On a 9:1 81mm b16 on 93, depending on dyno, maxing at 480 whp looks legit for a 20lbs/min turbine side.
Again it was just a speculation.
no balor for sure is 0.63...
maybe this week I will have news...I will try some things about ic and after turbo.
Most times when they F up they dont admit their mistake.
#27
Moderator
Biggest i saw with .63 / gt35 93octane(100eu) combo was 500 or 550whp on a 84mm b16 from a person i know here at Greece. It would not go higher.
#28
Its ok most of the times i post during office time and many times i type with leaving too many things just in my mind.
It happens alot.
It happens alot.
#29
Finally intercooler looks ok I put a boost gauge before cooler and after cooler and pressure is the same...next test an other gt 3582 turbo.
#30
Moderator
Just make a note of that...
#31
I will try...but if turbo is not my problem?what next?
#32
#34
#35
Shodan might be correct.Blade design might be way off.
Noone uses the a genuine GTX compressor wheel when he converts from GT35 to billet whatever right?
Do this and pressurize everything.
Sometimes leak in the intake manifold were it meets the head at the flange is hard to notice.
You may have leak on the turbo its self on the backplade or something.
Google " ταπα valsir " and get the correct size.
Just dont me this is not a mustang dyno! haha. Your tuner didnt hear any knock with the acoustics at higher boost right?
I would also check cam timing. Maybe one of the cams is wrong and the engine has too much overlap ?
Im getting out of ideas...
#36
13psi at 450hp is at 78% efficiency
20psi at 480hp is at 78% efficiency
25psi at 475hp is at 78% efficiency
25psi at 550hp is still high at 76% efficiency, and at 600hp is still high too at 74% efficiency
#37
While still ok, it's off the center island. Meh, potato - potahto.. Efficient though not optimal is maybe what I might have said? Not a tremendous jump either way. Would explain why lower pressure performs better than highest. It's ONLY a 5hp drop on 5 psi. It is also a drop on the compressor map. I don't know if THAT makes much a difference, but I'm just showing what stares him in the face here. **shrug**
#38
Anything above 75% is considering excellently ideal. And above 70% is still considered well usable. Hell, I'm making 440whp (~500 crank hp) out of a turbo that is supposed to max out at 350hp. I'm below 60% efficiency in mine in higher rpm's. IAT's climb fairly rapidly, but it still makes the power perfectly fine. And it's not even a BB turbo
#39
The island just means peak efficiency. The difference between 78% and 76% just means IAT's will be 3-5 degrees F different, and exhaust pressure will be a tenth of a psi or so different. Barely measurable in any other way. Below 70% you'll start to see some minor power differences. But it's not until you go below 65% (or outside the surge lines) that you start running into problems.
#40
Update
Problem solved....
Yesterday I tried an other gt 3582 with billet gtx wheel and at 21-22 psi the car make 550 hp with 10.8 afr and very safe ignition timing!!!
Problem solved....
#41
#43
#45
#46
Moderator
Umm.. Ok. No such thing as an "authorized" knock-off specialist. That implies that Garrett authorized the design of the wheel. Which.... doesn't happen..
But whatever, as long as you feel you've solved the issue.
#47
Moderator
Umm.. Ok. No such thing as an "authorized" knock-off specialist, for a genuine knock-off. That literally makes no sense.
#48
#49
Id bet they overdid the lateral clearance on the compressor housing.
#50
I run knock off billet wheels in my turbos too. Specifically Kinugawa and Mamba. They actually work amazingly well, and they come component balanced. I had my turbine wheel component balanced a long time ago. Threw the assembly on a balancer, and it was darn near perfect, didn't even touch it. Destroyed the compressor wheel when it sucked my screen in, bought new wheel, threw that assembly on the balancer, again was nearly perfect so I left it. I run mine well over 175k rpm, and it's journal bearing with a 360* thrust bearing. Zero issues, and I currently make 440whp in a turbo that's supposed to max out at 350 crank hp. Which I know to be true, because that's the whole reason I bought the billet wheel to begin with. Couldn't get over 310whp no matter what I did. Bought a drop-in billet wheel, boom, 400+ right off the bat. Turbo is a water cooled Garrett 60 trim T3 with 0.63 a/r 5-bolt housing, oem turbo from the 80's SVO mustang, and it has over 350k miles on it currently in total between my car and the mustang it came off of. I've put new bearings and seals in it 3 times.
