Troubleshooting: B16 turbo has low boost pressure after installation & tuning.Causes?
Hi to all I would like your opinion about my problem.. i have a B16a darton sleeves 81mm 9.0:1 gt 3582 billet wheel 0.63 a/r ramhorn 44mm 80mm exhaust ferrea valvetrain T1 trigger with stand alone ecu and k20 coils id 1050 at 13 psi makes 450 hp and when we start go up at 20 psi makes 480 and at 25 psi 475... for sure is not normal this.... intake temperature was 80 f. engine is fresh and very healthy. any idea what happens??? |
re: Troubleshooting: B16 turbo has low boost pressure after installation & tuning.Causes?
Is this a Garrett 3582?
Yes Garrett 3582 and I have put billet wheel |
If the motor is healthy then my first look would be the turbo not being up to par.
Originally Posted by Autoworks
(Post 51887494)
Did you test for air charge / exhaust leaks?
Its looks that the system uses much more power than its should to keep the asked boost target. There a rare chance that you hook your wastegate vacccum line before the intercooler and the intercooler is getting maxed on flow/cfm This way everything works great until you max the intercooler flow THEN it creates wall of restriction and you have like 35psi before the intercooler and 20 psi after it. Are you sure the guy that did the turbo did a good job? |
Originally Posted by Balor_Gr
(Post 51887584)
what fuel are you using?
The fuel alone could be the entire cause of this |
Originally Posted by motoxxxman
(Post 51888116)
Originally Posted by Txdragon
(Post 51888222)
5hp loss within a 5psi boost increase.. Think maybe boost ignition correction could be affecting here?
Re: B16 turbo low hp after boost
Originally Posted by fotis2000
(Post 51888349)
100 Ron fuel.we try different ignition timing with no results... Does the car have a catalytic converter installed? Cats can be extremely restrictive, especially if they start to clog up |
Re: Troubleshooting: B16 turbo has low boost pressure after installation & tuning.Cau
You nearly doubled the boost pressure and only gained 25HP? Something is definitely wrong...
(Post 51889063)
that might be why. You're at the edge of the knock limit of that fuel.
Does the car have a catalytic converter installed? Cats can be extremely restrictive, especially if they start to clog up the fuel is just perfect my friend for this set up until 600 hp at this dyno |
... change the turbo
(Post 51889195)
No catalytic converter on the car... the fuel is just perfect my friend for this set up until 600 hp at this dyno 100 RON is the same as 93 Ron+Mon/2 here in the states. And knock limit on our 93 occurs around 400hp-450hp on most hondas, some reach 475 and blow up soon thereafter |
(Post 51889206)
(Post 51889203)
(Post 51889235)
100 Ron here (Europe) is 100ron not like USA
Read what I said again:
(Post 51889206)
100 RON is the same as 93 Ron+Mon/2 here in the states. And knock limit on our 93 occurs around 400hp-450hp on most hondas, Some reach 475 and blow up soon thereafter |
(Post 51889459)
Yes, I am very aware of that. Which is why I'm glad you stated 100 Ron instead of just saying 100 octane.
Read what I said again: The characteristics of USA 93 octane are the same as Europe's 100 octane, because they are exactly the same fuel. Meaning The same power figures apply to you. And is probably the reason you're not gaining any power as you raise the boost. To get over 450hp, you're going to need 105-110 Ron gas. with 100 octane you can go very far...I have many examples my friend sorry... my last set up with gt 3076 was 530hp at 26 psi... |
(Post 51889497)
Not correct.... with 100 octane you can go very far...I have many examples my friend sorry... my last set up with gt 3076 was 530hp at 26 psi... |
What size intercooler and what type of cams do you have again
Originally Posted by ls joker
(Post 51889608)
itr cams |
Are you sure thats a .63 garrett housing? That behaviour is close to the back pressure
wall from a too small housing. I know tjere isnt a garrett .48 for the gt35 maybe something else? Just saying. |
(Post 51889658)
wall from a too small housing. I know tjere isnt a garrett .48 for the gt35 maybe something else? Just saying. maybe this week I will have news...I will try some things about ic and after turbo. |
(Post 51889658)
