Tranny rebuild
Re: Tranny rebuild (sleepin91teg)
depends whats wrong but most time 5th gear syncro set and 3rd gear syncro set def all bearings and possibly shift forks
Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">can an average guy do his own rebuild??</TD></TR></TABLE>
depends on how average you are
Re: (h22 civic)
what if you did all the work to build your own motor and installed all turbo components ex. after machine shop did there stuff. i installed pistons,rods, crank, head, cams, etc.. i can do measurements for cam to rocker arm spacing torque specs but can't (haven't tried) measuring for bearing clearances (rod or main)
Re: (incredteg3)
like anything involved with the motor... you need some experience ... if your mechanically inclined then yes you can rebuild a tranny , but just make sure you have a helms there as there are a lot of pieces that need to be put together properly or your screwed.
Re: (incredteg3)
Get the Helm's, read the chapter on transmissions. If you aren't worried after looking at it, I say go for it. Be ready to buy some tools, though, if you don't already own various pullers, measuring devices, etc.
VelocityR
07-31-2003 11:15 AM
