Traction with B16a Turbo??
I was scrimping threw the achieves, and couldn’t find what I was looking for. I want to know how bad of a traction issue I’ll have with this setup. 95 vx hatch, B16 SiR2, Drag 3 Turbo Kit @ (7si), Y21 Lsd Trans, with 15x6.5 195/50/15 yoko avs 100 tires. For suspension, all I have are ground control springs 1.75in drop. Any info, or how to improve my setup would be greatly appreciated. https://honda-tech.com/forums/images...es/emsmile.gif
Re: Traction with B16a Turbo?? (95VXB16A)
ttt
almost every fwd turbo car without an lsd has traction problems...what ya got is fine.
Re: (quik sol)
thanks for the insight https://honda-tech.com/forums/images/smilies/emwink.gif , anyone esle?
Re: (95VXB16A)
well when i had my civic turbocharged i had crazy traction problems, quik_sol is right, you can avoid traction problems with FWD cars...drag radials do help, and i found that raising the back of the car just a little higher than the front helped also...but then this would mean coilovers.
