Tony,Earl,Viren,Geoff and other master of building motors
I have some questions to ask: Is it possible to use an LS crank with stock rods and ITR pistons in a GSR block? if so, will the crank or rods would hit anything enternally? Like oil squirters and such? have you guys have done this before? and what do you have to do to get everything right. My friend have a 98 GSR and he took his car to one of his buddy to get his head port & polished and replaced the valvetrain. Then, when his friend put evrything back,they forgot to tighten the crank pulley bolt and it flu out and tore the slot of the crank where the keyways goes into. More likely the crank is no good. This is why I"m asking if its possible to put an LS crank,rods and pistons into a gsr block. I'm sorry for a long story.
Re: Tony,Earl,Viren,Geoff and other master of building motors (boostedb20vtec)
Yes the LS internals will fit ina gsr block fine
edit: I'm sorry geoff, I didnt mean to offend you with that statement, I was mostly harasing the newb
[Modified by UberTeg, 9:11 AM 4/2/2003]
Re: Tony,Earl,Viren,Geoff and other master of building motors (ninesecrx)
yes you can and you will end up with a stronger ls/vtec setup.
_______
Ok, but anyone here have done this, what 's the hardest part of it and any clearance problem? how bout the mains, do I need to use all gsr parts? like girdle,oil squirter, oil pick up,screen and all that?
_______
Re: Tony,Earl,Viren,Geoff and other master of building motors (Arturbo)
Off the subject, but Art is gonna LOVE the title to this post.
Inside joke..
Inside joke..
Re: Tony,Earl,Viren,Geoff and other master of building motors (tony1)
Inside joke..
I get it...
Inside joke..
I get it...
[Modified by UberTeg, 7:30 AM 4/3/2003]
_______
How many inside joke do we have ? are we talking about the "catering truck thing " tony ? Art ?
stan
Re: Tony,Earl,Viren,Geoff and other master of building motors (Flamenco-T)
I guess there's a lot of master of inside joke around here.
Stan, thanks for the info. Where can I get the plug for squirter at. Or maybe should I bend them a little bit so the crank would not hit them? I seen this guy on here with lots of pics of his B20vtec set up that he put those squirter and he had to bend them all to clear the crank. Here's the link:
http://vtec20.8k.com/cgi-bin/i/motor...quirt_hole.jpg
http://vtec20.8k.com/cgi-bin/i/motor...squirt_rod.jpg
http://vtec20.8k.com/cgi-bin/i/motor...uirters_in.jpg
http://vtec20.8k.com/cgi-bin/i/motor...rter_close.jpg
http://vtec20.8k.com/motor_build_pics/
you can bend the nozzles, but you still have to figure out the way to clear the bolt that holds the squirters down to the block. But you can try it to see if it can clear the crank by bending the nozzles...
if not, you can buy a set of freeze plug to plug the holes up, it's 6x1.0mm about 5mm deep, I'd say..
good luck
stan
good luck
stan
1 Post
Re: Tony,Earl,Viren,Geoff and other master of building motors (DIRep)
Those pics you posted...that guy actually had the crank hit the squirters while the motor was running. Blew the motor pretty quick actually..
Suprdave
Suprdave
1 Post
Inside joke..
Suprdave
Re: Tony,Earl,Viren,Geoff and other master of building motors (Suprdave)
Inside joke..
I'm guessing it has something to do with Viren? Someone PM me the 'inside joke'
Suprdave
Suprdave
You forgot your [assholemode][/assholemode] tags
Inside joke..
Inside joke..
Re: Tony,Earl,Viren,Geoff and other master of building motors (Bryson)
The inside joke doesnt have to do with anyone in particular but everyone as a whole.
People think I can do it all when in fact I cant. Everyone has a weekness. Nothing wrong with addmitting you cant do it all.
Keep it real
art
Keep it real
art
How's the build going? forgot to ask you about it last weekend.
me, slow. But it'll be pretty sweet cause we're messing with EVERY little detail.
1heavy4dr
07-26-2005 05:26 PM
