Tire help
i need to know what tires i can run
i'm about to get the 5zigen fn01r-c 15x7 in black with polish i want to run drag radials in the front and regs in the back also i wanna run as fat as a tire in the front without rubbing and decent turning i have a full omni power suspension setup i would like little wheel gap what about these for the front - 225/50R15 front tires rear - 205/50WR15 rear tires again they are going on a 15x7 rim on a 94 teg what about that setup????? plz lemma know https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif I NEED TRACTION https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif thx https://honda-tech.com/forums/images...es/emsmile.gif Modified by lucidvtec at 4:09 AM 2/9/2006 Modified by lucidvtec at 4:12 AM 2/9/2006 |
Re: Tire help (lucidvtec)
http://www.tirerack.com/tires/...FTADR
these are the tires u want the 225 will fit as long as you are not super slamed they are great for the price and the 225 have more tire to grip then the 205's great street drag radial they tend to wear kinda quick tho |
sweet...that will work perfect for my front tires
i know they were quickly..but it's worth the traction for the rears...i don't wanna run a drag radial i'm thinkin a 205/50R15 |
Re: (lucidvtec)
check first post...k thx
Modified by lucidvtec at 4:10 AM 2/9/2006 |
Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec »</TD></TR><TR><TD CLASS="quote">sweet...that will work perfect for my front tires
i know they were quickly..but it's worth the traction for the rears...i don't wanna run a drag radial i'm thinkin a 205/50R15</TD></TR></TABLE> ya runing drags in the rear would be a waste of money, run whatever in the rear falkins or whatever is cheap, what u have there is fine, your not autocrossing the the car or anything are you? |
i don't think i will AC this car.....but have a set of 16x7 for AC if i wanna go with the right tires
this is for my street setup...but i wanna roll to the track without taking slicks.....i think this setup is pretty balenenced |
| All times are GMT -8. The time now is 12:45 PM. |
