Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Tips on installing HKS SSQV BOV (https://honda-tech.com/forums/forced-induction-16/tips-installing-hks-ssqv-bov-171397/)
Total'd GSR Apr 24, 2002 09:45 AM
I have the HKS SSQ with the flange welded to my UIC piping. I put the gasket in the flange and test fit the BOV but it seems to not be a tight enough fit. Will the metal clip make it fit snug?
Flamenco-T Apr 24, 2002 09:49 AM
Re: Tips on installing HKS SSQV BOV (Tanabe'd GSR)
yes the metal clips is what hold the BOV in the flange and make it leak proof...
use a special pliers..I forgot what it called....I'll find out in a few....otherwise, good luck, you'll never get the BOV in the flange..
with this pliers, it took me 5 minutes and I have done 2 so far...
VaporTrail Apr 24, 2002 09:59 AM
Re: Tips on installing HKS SSQV BOV (Flamenco-T)
you need a set of C clamp pliers, make sure you get the right size, and have some patience. It's a very secure design
intekragsr Apr 24, 2002 12:20 PM
Re: Tips on installing HKS SSQV BOV (VaporTrail)
it took me a half hour to install that damn thing. I used 2 flathead screwdrivers http://images.zeroforum.com/smile/emsmilep.gif Dont ask me how, just got creative. Make sure to tape the side of the bov so you dont scratch it up in the process. http://images.zeroforum.com/smile/emthup.gif
Total'd GSR Apr 24, 2002 08:02 PM
Thanks guys!
turbosol Apr 25, 2002 06:53 AM
You can also take the outer cover off of the BOV, its every other screw on the front . It allows for alot more room to work.
