Timing Question for Stock B16 running 9psi
Hello, Myquestion is whats a good # of timing to run in vac before the turbo starts spooling, I have a LS tranny so between 2000-3500 feels Sluggish in 2nd gear ,and its 20 degreese at WOT untill 4k when it starts building boost
Modified by OverboostJosh at 6:50 PM 7/20/2006
Re: Timing Question for Stock B16 running 9psi (OverboostJosh)
does the timing ramp up to 20* at 4K rpms or do u have all the timign set at 20* from 0-4K rpms? the lower the timing on the lower rpms will help the turbo spool up quicker but too little timing will raise the EGT's
