timing off by a gear to half a gear...will it affect my motor when i put on the turbo?
like my topics says, will the turbo hurt my motor if my timing is off by a little bit? i do have a adjustable cam gear to advance or retard my timing plus my dizzy. i just dont want to be advancing my cam gear and then retarding my dizzy or what not and messing something up. also, can i still redo my timing with the turbo on?
fix the timing belt. shouldnt take long.
if you dont youll probably be fine temporarily if u just need to drive the car a couple miles. id just be concerned with piston to valve and valve to valve clearance. the specs of the motor internals determine this
Re: timing off by a gear to half a gear...will it affect my motor when i put on the turbo? (ek4__)
Don't be lazy do it right the first time. you wont have to be concerned with clearance issues ,fuel consupmtion or any other lil bugs b/c of timing when you boost
Re: timing off by a gear to half a gear...will it affect my motor when i put on the turbo? (Bleedinh
if the head is milled
its normal to be off by half a tooth
well i want to redo everything but it is a b!tch to get that crank bolt off. the first time i redid my timing belt it took forever to even get it all lined up...but finally i got it to half a gear so i just stuck with that. is there a certain way to redo my timing belt and even if im off by half a gear can i still correct that with my cam gear.
XVNVX
08-07-2017 10:31 AM
ek4__
08-03-2006 08:15 PM
downeyballz
06-06-2005 11:10 AM
