Timing monitor
Timing monitor
Is there a way to know how many degrees of timing you are set at electonically. I was thinking about designing a sw program that will monitor all stats of the engine (all temps, boost, rpm, tp). Therefore needing an analog or digital input for the monitor.
Re: Timing monitor (grngsr01)
Hondata, AEM EMS etc.
Not worth it to do it with a stock ECU and say an FMU setup or AFC when the extra money spent can be put towards the above.
Re: Timing monitor (Foozball26)
Thanks for you insite, but is ther anyway to monitor the timing electronically like i asked without a full stand alone setup...
Bailhatch
01-12-2004 04:05 PM
