Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Time to Upgrade. Input needed (https://honda-tech.com/forums/forced-induction-16/time-upgrade-input-needed-2922610/)
frogg5872 Apr 12, 2011 02:06 PM
This is my current Setup. made 325whp/290tq. I Would really like to get it up around 450 on pump if possible and over 500 on race again if possible. What route would I have to go to get there? Car only sees 2500 miles a year.
b18b - Benson built bottom end - bored to 84mm
Eagle Rods
CP Pistons
Crane turbo cams
STR cam gears
SuperTech Stainless Steel nitride coated valves
Dual valve springs
Titanium retainers
Competition 3 angle valve job (Portflow)
Turbo Info:
GT3076 - .48/.63 trim
Precision 880 cc injectors
Precision 600 hp intercooler
Drag Turbo intercooler piping
HKS SSQV BOV
Neukin 3" recirculated Downpipe
Neukin A/C friendly ramhorn manifold
3" Thermal Exhaust
Tial 38mm Wastegate
spoolinvtec54 Apr 12, 2011 04:33 PM
Re: Time to Upgrade. Input needed
Everything looks good. You might need to get 1000cc injectors. What kind of race gas.
LightningTeg Apr 12, 2011 05:13 PM
Need a better cam man. Those cams are junk if you are only making 325 at 16psi. With a similar setup on crower 404s Im making 370 on 15psi
Turbo-LS Apr 12, 2011 05:23 PM
Yeah but the crane and crower turbo cams idle really well, they move the powerband up about 800-1000 rpm . the smaller exhaust housing wont help with power IMO
LightningTeg Apr 12, 2011 05:45 PM
16psi is stock cam numbers. On a ported head they are obviously doing nothing for him
Turbo-LS Apr 12, 2011 05:49 PM
true but on a 2L motor that .48 turbine housing imo is probably choking the potential of the motor. the larger the turbine housing and turbine wheel you can get more hp at lower boost. for example the 6262 nad 6265. the 6265 has larger turbine wheel and can only come in a .82 housing or larger and you can obtain the same hp and lower boost leves at the staright 6262
darkvader0 Apr 12, 2011 06:08 PM
Yeah ditch that .48 man. It's killin you. At least a .63 or even an .82 if you decide to move the powerband up a little with cams. Good news is it's an inexpensive upgrade. :)
W!d3b0dYr3X Apr 12, 2011 10:48 PM
Definitely will need bigger injectors, and bigger turbo. Do u already have an aftermarket fuel pump? Surprised no ones mentioned that if not u will def need one
AllShowNoGo727 Apr 13, 2011 05:51 AM
I think you will like the turbo cams.
TheShodan Apr 13, 2011 06:11 AM
Turbo Info:
There is no such configuration. Are you sure you simply don't have the standard .63A/R in either a T31 2.5" 4 bolt , GT 3" 4 bolt? There is no .48 Compressor or exhaust housing option from this turbocharger.
frogg5872 Apr 13, 2011 02:46 PM
I just copied and pasted from the sale add I bought the car from. I have an aftermarket pump in already. So looking like I should look into some 1000cc injectors and a larger housing maybe some cams? Where is a good place to buy a a larger housing. There are a million sites to buy parts from, I just dont know who is best to deal with.
frogg5872 Apr 13, 2011 02:50 PM
Anyone have anything good to say about the new GTX series turbos?
frogg5872 Apr 19, 2011 01:23 PM
http://forums.evans-tuning.com/viewt...&t=3927#p22960
This is the dyno of the car. It even says its a .48. So i am confused because I searched and could not find that spec? Any one know where I can get an upgrade kit for this turbo online?
SovXietday Apr 19, 2011 01:37 PM
You're definitely choking with the housing, but like Shodan said there is something fishy about that turbo.
Post pics? Either way, that's your problem. And as for making 500 on an LS, all you really need a VTEC head and a bigger AR, probably a .82 for best results.
97CWITR Apr 19, 2011 01:44 PM
vtec head, ID1000's, bigger turbo.
keep uping the boost til your happy.
LightningTeg Apr 19, 2011 03:38 PM
I also dont see the benefit of the cams if your not even revving them past stock
frogg5872 Apr 24, 2011 11:00 AM
I will get some pics of it or even try to find a part number. As far as vtec heads go do they have any weak points in them or is it as simple as bolting one on and your good to go to XXX amount of power.
DelSolMarine Apr 24, 2011 11:31 AM
like jeff said... the turbo is the restriction... ID1000s are a must
frogg5872 Apr 28, 2011 07:28 PM
700382-5012 are the numbers i could get. I think it a .60 then? I am lost at this point. Any logical and useful input is welcomed.
office2222 Apr 29, 2011 03:33 PM
Jeff never adjusted them when I took it to get tuned. Why he didn't do that, I'm not sure, but he didn't.
I know the housing is small but i built the engine so it would be a street beast...that's evidenced by the fact that full boost is reached very early and spool is pretty much on demand.
If he wants to upgrade, a larger trim is necessary, i agree.
Also, ditching the recirculated dump wouldn't be a bad idea. I put that in to keep the car streetable and livable - read: quieter. Ditching that would free up some power.
Other than that, you're looking at a VTEC head. I wouldn't do it. I'd get the larger trimmed turbo and ditch the recirculated dump and see where that gets you. That head doesn't have many miles on it and it's completely rebuilt and upgraded. No need to throw it out.
The head is not ported, however. It was just "refreshed" since the original OEM head had 150k on it.
B00st3d-dc2 Apr 29, 2011 04:35 PM
Vtec head, ID1000s, 82 backhousing
Or if you really wanna make use of this lovely setup add a gt3582r and skunk2 tuner 2s along with the above
TheShodan Apr 29, 2011 04:38 PM
Yes, that's a GT3076R. Yes that uses a .60A/R compressor cover. No, it does not use a .48A/R turbine housing. Sounds like a typo. Either way, you won't do 500whp on pump gas with it, as it is only 52lbs/min. You need to go up to about 58lbs/min or slightly higher to do it.
office2222 Apr 29, 2011 04:47 PM
I know it's not a typo...he can look on the turbo itself. I ordered it from neukin....not sure if he put a different housing or not, but it IS .48.
frogg5872 May 1, 2011 02:48 PM
so then to upgrade the turbine housing to an .82 what would I need. Just the housing?
office2222 May 1, 2011 05:22 PM
I believe that's it, but I am not positive. I've never looked into that and now I don't have a turbo, haha.
