THINKING ABOUT BYING A TURBO KIT HERES WHAT IT INCLUDES WHAT ELSE WILL I NEED
TURBONETICS-57 TRIM SATGE 4 WHEEL .50A/R .63 EXAUST , MANIFOLD, 35MM WASTEGATE, INTERCOOLER WITH PIPING, CLAMPS ,RUBBERS. DOWNPIPE ALL OIL LINES AND FITTINGS, FUEL RAIL . BESIDES A FMU IS THERE ANYTHING ELSE I WILL NEED . THIS WILL BE GOING ON A GSR
You'll need some kind of fuel management (uberdata, hondata, fmu, etc...). If you're using an FMU, you'll also need an inline fuel pump.
Re: (bubs)
SO THATS IT OH AND A MISSING LINK RIGHT
Re: (94integragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr »</TD></TR><TR><TD CLASS="quote">SO THATS IT OH AND A MISSING LINK RIGHT</TD></TR></TABLE>
Yeah, but I would recommend using Uberdata or Crome since you are OBD1. In which case you would need to get your ECU socketed, a ROM burner, and some chips. Also, a wideband would be helpful unless you are going to have someone else tune the car. |
Re: (94integragsr)
i just did a hmt and we where going the fmu way till i realized its just better and as cheap after all to get a chipped ecu and have it tuned.but if you go fmu dont plan on anything above 10psi and i think 10 is pushing it
chipped ecu are for sale in the classifieds here all the time,pick 1 up and run a base map to get it to the shop for a real tune .oh and bov not needed but gd idea,and keep your dumptube or if you run a open wastegate keep the fumes away from the turbo inlet.i just blew my rings and turbo seals sucking the hot gases back in |
Re: (93cicvicls)
forgot to add make sure you have somekind of flex pipe on the downpipe i didnt and broke bolts,welds and such till i fixed it right
Re: (94integragsr)
oh and maybe a new keyboard since your shift key is stuck. STOP YELLING AND YOU'LL GET MORE HELP http://images.honda-tech.com/set1//smile/emcrook.gif |
Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">
oh and maybe a new keyboard since your shift key is stuck. STOP YELLING AND YOU'LL GET MORE HELP http://images.honda-tech.com/set1//smile/emcrook.gif </TD></TR></TABLE> +1564641 Just make sure you get it tuned after you install everything, it ill be the best money spent so don't cheap on the tuning. https://honda-tech.com/forums/images/smilies/emthup.gif |
