Are these rc injectors seated correctly in my fuel rail? *pics*
i have a set of 1200 cc rc injectors i am rying to install onto my vitor x intake mani. I used a new set of oem injector seals and i was just wondering if they are installed correctly? to me it looks like its pinching the seal...i did not dremel/bore out the o rings and i just read a thread where someone said they fit perfect with oem seals but you have to cut the seal in half...which i also didnt do..are these installed correctly? any help is appreciated
http://i1053.photobucket.com/albums/...1C426BA8F2.jpg |
Re: Are these rc injectors seated correctly in my fuel rail? *pics*
it looks right
i think you can check for leaks once your fuel pump is primed, you can see if the injectors are leaking gas. i could be wrong but i think that is one to check for leaks before you fully crank the vehicle up |
im looking for the fuel rail... lol
mis-leading title |
lol..i was thinking intake manifold as i was typing fuel...sorry
and thanks |
You should NEVER cut a seal in half... you are supposed to sand off the ring/lip that is in the inside. Also, that side of the injector isn't that big of a deal as it seals off vacuum/boost only. The other end however, is the side to be concerned with; it holds back fuel pressure/fuel.
The seals look very tight but as long as it doesn't create a vacuum leak it isn't a big deal. |
they are seated correctly. RC injectors sit "on top" of the seal, not fully inside. there are RC instructions floating around somewhere that will confirm it
Originally Posted by dpetro1
(Post 47754027)
