THERMOSTAT...YES, THERMOSTAT *SOLVED*
#51
re: THERMOSTAT...YES, THERMOSTAT *SOLVED*
Take off the clip then.
I don't like the need for more routed air thing.
Your not explaining the rise in temps.There is no imaginary threshold between cruising at city 40MPH and 65MPH. If anything you have more air penetrating farther with little change in load.
The puller fan and fresh ambient air are still available.
#52
ok. Suppose it IS blockage as you suggest. Not enough airflow. Small intercooler seems to be obstructing the radiator, which causes the car to overheat. Going with that theory, riddle me this Batman: why doesn't the same exact car overheat in stop and go traffic? same intercooler. Same radiator. Same blockage. NO overheat. If the obstruction is there on the highway, that SAME obstruction is there in the city, right? But In the city, the car doesn’t overheat. And usually people who would be having these type of issues usually have them in the reverse order: heats up in stop and go traffic because of a lack of flow, but runs cool on the highway because of INCREASED air flow... so I’ve heard lol
Do it. Remove the intercooler and install a straight section of pipe in its place. I guarantee your cooling issues will vanish immediately.
#53
#54
Is he not using a 2 in 1 Koyo radiator intercooler system, that cannot be separated?
Yall liked my idea of running no intercooler on my Accord, now it solves everyone's problems. Unbelievable.
#55
No no, that's not what was said. It was said to remove the intercooler **BRIEFLY** for the sake of testing airflow blockage to the radiator. It's an EG chassis with a triple core, half size radiator. I really don't believe airflow is the cause here.
#56
Have you checked the thermostat yet?
You pressure tested it and said you found no leaks. It is not distance or time related , but triggers a overheat at constant 65MPH. I'd go back to thinking, lean on a low speed fuel map if it wasnt a hanging stat. Live tuning shows it is not severe enough to be displayed on the wideband. Its far out there , TX dragon makes a good point.
Because if it was so lean on the low speed maps, it would also be lean in the city.
That is not ducting, guys. It would need ducting in the city too.
#57
I believe the theory is that on the highway, you're relying on the speed of the vehicle to cram air through the intercooler, then through the radiator - air is being forced in from the front. Since the intercooler is in front, it's going to see the biggest benefit from the air being forced in, and the radiator will see diminished cooling vs. if there was no obstruction (the intercooler). In the city at lower speeds, cooling relies less on the speed of the vehicle and MORE on the puller fan. Since the puller fan is mounted on the back side of the radiator, the radiator will actually see better cooling than the intercooler. Without ducting, the radiator fan can draw air through the radiator from between the radiator and intercooler. This is why despite the fan running it's little heart out in stand-still traffic, you will still see your IAT's climb - it does a better job of cooling the radiator than the intercooler. This is also why pusher fans can be bad for turbo setups - it's between the radiator and intercooler, and just slows the air down even more at highway speeds, causing the radiator to heat up even more.
#58
the engine only produces about 1/4 of the heat in stop and go traffic and mild city driving as it does while highway cruising. At these lower energy (aka heat) times, the fan[s] are enough to cool the system/engine and maintain a normal temp. At higher energy times (highway) airflow from fan[s] and/or vehicle speed is simply insufficient. It needs more airflow. This problem is very common with turbo cars that were originally non-turbo. Keep in mind that at low vehicle speed, the fan[s] will pull air from anywhere and everywhere and direct it through the radiator. While at highway speed, it's relying solely on air coming through the intercooler, because the shape of the car is directing all other airflow sources away. The main issue though is the difference in heat produced by the engine at the different speeds/loads
In addition, a puller fan will DRAW air through the intercooler and radiator at a specific location... and if the fan has a shroud, that air will be drawn from a greater surface area and thus become more efficient in cooling the radiator. In contrast, when cruising down the road, air merely enters the openings on the front end of the car and passes through your intercooler, radiator, condenser and coolers... but the path that it takes is that of LEAST RESISTANCE... and that path may NOT be through the entire radiator.Ducting forces the air to pass through the devices that you direct the air through, increasing the effectiveness of the air flow.
#59
1:05 a.m. EST - ok well I replaced the Mishimoto thermostat and car went UP to 219 degrees within 1 highway exit!...dammit....pulled the intercooler for ***** n giggles and car still overheated. So much for my intercooler being the culprit and blocking air to the radiator. Im going to be M.I.A. for a few and basically tear this thing down..left and right sides...NOT removing the head...and going to try something else for cooling.. be back in a few days with my results/findings
#61
#62
Premium Member
I didn't read every post of this thread so I'll ask; has anyone mentioned ignition timing values yet? OP are you tuning it yourself? What do your cruising timing values look like? Overly retarded ignition timing values will cause overheating. Especially under constant load conditions like on the highway if you're constantly in a cell or table that hasn't been tuned correctly...
#63
Does the reservoir's level stay the same? Are you filling it back up? Coolant pressure leak? If it holds pressure overheating does not happen as fast. If there is a pressure leak it overheats rapidly. The behavior is trying to tell something.
How are you flushing the cooling system? That seems fast 1 exit. There is a special funnel thing that attaches to the radiator, did you use it?
It is easy to overlook the low speed maps when tuning. I suggested this as there is a lean spot not accounting for map sensor load. At a constant load, in one Hondata column, it could be being held lean . Far out there cause why not in city, that is the same column area you are driving on 40 or 65MPH.
#64
#65
Damn, that really sucks. I was really hoping that T-stat would get ya going. Gave the airflow a try as well, good deal, but it was a long shot. Given everything that has been done and now tried, I'm fresh out of ideas. Unless there's a coolant passage blockage somewhere. **shrug**
#66
#67
new thermostat, and removed intercooler, and still overheated. That too tells me there's a blockage somewhere, or a lack of flow from something.
Before you pull the head; take the water pump off and inspect the blades. I know it sounds strange, but I've had a few cars where the impeller fell off the shaft, and other cars where some of the blades actually broke off the impeller wheel and lodged themselves in the coolant passage. While the pump is off, try looking into the coolant passages to see if anything is making a new home where it shouldn't be.
#68
Lisle 24610. If it was not used you cold let it idle for an extended time and the bubble /cavitation would work its way out.
You said it had pressure. The blades didnt fall off.
Because of the rate of the coolant boiling vs. the position on the gauge. You have me suspecting it is NOT holding pressure. It would not boil so soon.
#69
🤦🏾*♂️ I didn’t say it was boiling. And for the 12th time it IS holding pressure. No leaks. No coolant disappearing. NONE. It’s just getting up to 220 degrees, where it should NOT be...
#70
An engine comming to a boil , out the overflow, is overheating.
An engine running hot is holding at 220. This is running hot .
I noted my turbo'd vehicles ran hotter above 200 was common. But they did not overheat. If your radiator is a smaller capacity or different style of internal flow it could be the problem. A vehicle runing at 220 temp will not melt or warp the aluminum its made of. If anything it will feel soft off the line, letting out the clutch from the heat. Not going to mechanically fail. It will not have excessive heat losses till much later. And the moment air flow increases it would cool down.
The standard flow of air at the front of the stock fascia is sufficient for cruising at 65MPH. You can try to give it more , but that has never been a problem so yer on your own with that theory. I did a handful of them and never had a problem with the stock cooling system. You should also see it on a TEMP infra red gun. It would be a contributing factor but never the cause.
Use a running fan at the front of the car to determine how much blockage you might have. Feel with your hand how much air the intercooler blocks. You should also see it on a TEMP infra red gun.
Why not take off the clip, it takes 10 min, go fer a drive report back.
This kinda thing works when people bounce ideas off each other. I really don't have much useful diagnostic information. Pictures are good.
#71
#72
****winner winner steak and shrimp dinner.....Aradin guessed it. Apparently the intake cam was the culprit. It decided to relocate and rotate a couple of degrees to the right which threw everything off. The intake cam timing was retarded... Mechanical timing was the issue. and i believe it might have been due to something getting inside the timing cover and making the belt skip. i usually have cover on in its entirety but i had to order a new upper. reset everything to TDC, timing gun set to "stun" and dizzy at 16 degrees BDC. car running at a cool 193. it did go up to 203 but then back down. probably an air pocket that will get worked out. Needs a tune now tho but at least the overheating has ceased as fair as i kno. gonna take it down to miami on the highway tomorrow night, maybe do a little street tuning on the way down and back. thanks for all the ideas and input.
#73
#74
Re: THERMOSTAT...YES, THERMOSTAT
yup. The intake cam was retarded. Then when u set the dizzy timing, it’s not true due to the intake cam being off. So, it was doubly retarded, mechanically and spark-wise. So the plugs couldn’t dissipate the heat fast enough due to being so retarded, which caused cylinder temperatures to rise, and the radiator couldn’t cool down the excessively hot coolant fast enough causing the car to run hot
#75
