Terance's 600hp Street/Track Build
Old 07-18-2017, 07:32 PM
  #151
GoldieWang's Avatar
Default Re: Terance's 600hp Street/Track Build
I want to see this beast live!
Old 07-27-2017, 11:49 AM
  #152
JDMarv's Avatar
oh man updates?!!?! lol
Old 07-29-2017, 09:09 AM
  #153
welfarepc's Avatar
Shielded wire is very important to ensuring the car runs properly. I have a feeling the shielding or grounding might be suspect in that harness if your issues started right after it was installed.
Old 08-08-2017, 07:24 AM
  #154
TeranceFL's Avatar
getting the Mechanic to come here this week so we can try and get it started. I would say if things go right within the next 2 weeks to a month we should be good. Hard to get everyone schedules set.
Old 08-08-2017, 08:10 AM
  #155
JDMarv's Avatar
lookin forward to it!
Old 11-21-2017, 10:00 AM
  #156
TeranceFL's Avatar
Car is getting tuned and aligned tomorrow, I'll keep everyone updated
Old 11-22-2017, 03:06 PM
  #157
TeranceFL's Avatar
Car made 560whp 375wtq with wastegate issues. Couldve went more but decided to play it safe for another time until I get a softer spring. Very happy with the power it made with little to no effort.
Old 11-23-2017, 06:27 AM
  #158
TeranceFL's Avatar
Old 11-23-2017, 07:29 AM
  #159
boosted94gsr's Avatar
Very nice! Good work man! 👍
Old 11-23-2017, 08:04 AM
  #160
1HGEJ2's Avatar
really really nice!
Old 11-23-2017, 01:12 PM
  #161
H22Honda98's Avatar
Do you have the dyno graph?
Old 11-23-2017, 02:25 PM
  #162
TeranceFL's Avatar
Old 12-04-2017, 11:31 AM
  #163
jim chuck's Avatar
Great looking car!
Old 01-01-2018, 10:32 AM
  #164
jay2415's Avatar
Sick build!
Can you update your spec sheet? I'm currently putting together a very similar setup.
any updates, thoughts on the setup after the tune? What are your thoughts on the 6262 performance on the the street?
Old 01-02-2018, 04:35 AM
  #165
LightningTeg's Avatar
Nice curve
Old 01-02-2018, 08:45 PM
  #166
B and B's Avatar
Did you find anything causing the misfire?
Old 02-01-2018, 06:58 AM
  #167
TeranceFL's Avatar
Originally Posted by jay2415
Sick build!
I try to keep it up to date I'll look at it again. 6262 is cool. I'm new to having a fast car, all I have to say is when it hits I got nervous and butterflies all at the same time.
Originally Posted by LightningTeg
Nice curve
thank you, thank you.
Literally the harness by CJs wiring. Put in stock harness and perfectly fine.
Old 04-13-2018, 02:40 PM
  #168
TeranceFL's Avatar
Got car retuned hoping my boost creep was coming from my wastegate spring being too stiff and like you see below no. Contact Sheepey and I'll be sending the manifold back to get a 60mm Turbosmart wastegate on there hoping it fixes the problem. Once that problem is fixed then we can shoot for more power
Old 04-14-2018, 05:27 AM
  #169
ls joker's Avatar
20psi from a 6psi spring is some serious creep. Post some pics of the wastegate when you get the manifold off.
Old 04-14-2018, 07:44 AM
  #170
Moderator
TheShodan's Avatar
I think it's the spring being too soft on conjunction with boost control (solenoid actuation cycles could be slower than with using an automotive solenoid).
After that, then wastegate upgrade.
But then again, you could always control the other areas AFTER the wastegate replacement
Old 04-14-2018, 12:12 PM
  #171
ls joker's Avatar
I can possibly see the creep coming from the solenoid controls. But, initially it crept with a stiffer spring. Thought i read somewhere 18psi, mite be another thread.
Old 04-15-2018, 02:33 AM
  #172
1HGEJ2's Avatar
did u try without boostcontroller? only vacuum line to wastegate?
Old 04-15-2018, 07:09 AM
  #173
Moderator
TheShodan's Avatar
To piggyback on this point, I hope vacuum line isn't using turbo compressor cover as a boost reference... That almost always leads to boost creep.
Old 04-16-2018, 04:00 AM
  #174
TeranceFL's Avatar
Wish I could've posted this sooner so I can hear your gues suggestions earlier cause I already have everything off and ready to be shipped today (lesson learned) so answer a few questions that I at least kinda understand. Yes we tried running it with the boost solonoid disconnected still creeped, yes it did still creep with a stiffer spring, and yes the wastegate opens all the way. I saw on a thread a few years back and everybody was having the same problem and a 60mm WG fixed their problem so I'm hoping.
Old 04-16-2018, 04:04 AM
  #175
TeranceFL's Avatar
so this is how it was connected when running off solonoid
When it was disconnected all I can remember is that it was connected to the right side of the turbo (I'm assuming thats the compressor side)
Quick Reply: Terance's 600hp Street/Track Build
