Tell me if my oil return will work...(pics)
First off, I oknw the line can be cut shorter....the only problem is, I am having my downpipe fabbed up and I want to give them as much room as possible. So, having said that, will this work, or is it absolutely necessary for me to take another inch off or so?
Banned
Re: Tell me if my oil return will work...(pics) (1.8t)
you dont have any low spots. i would say you would be fine. there is nowhere for the oil to go but down
AND TRIM THAT GASKET SEALER!!!!!!!!!
Re: (MAD ITR 55)
My buddy did the oil pan while I was at work....he put a little to much RTV on it . I am a co-op this semester at AU, so I work 8hrs a day which leaves little time to work on the car. He said he would lend a hand and do some stuff for me. I am gong to trim it, but I just wanted to get my oil return pics up so everyone could agree/disagree on them
as long as the end of the return line going into the oil pan is the lowest point in the line it shoud be all good, and it looks to be that way.
Banned
Re: Tell me if my oil return will work...(pics) (PRojectSi2)
I got a question... where is your downpipe going to go?.... seems the oil return is in the way.
mine was about in that same spot and i had to run a 1/4 of a quart lower oil tell i took it off and fixed it. then i movied it as high as i could go on the oil pan and was fine.
[img]http://www.auburn.edu/~mcgowmd/124.jpg[/img
koczeka
30
04-24-2007 04:55 PM
