TD04H into my D16 help!
Hey guys!
So I have got a TD04h with me, I am not 100% sure what car it's off but the serial code is 49189 - 00640 070310015.
I was wondering what oil fitting sizes would i need?
I was looking at -3an or -4an?
Do I need to have a restrictor? Previous owner said he had 2mm restrictor but his oil light came on, I would assume that pressure is low?
I believe I need to be running at least -10an for the oil drain?
Thanks guys
Thanks guys
Re: TD04H into my D16 help!
correct oil feed line
http://www.ebay.com/itm/Turbo-Oil-Feed-line-Kit-M10-x-1-5mm-Mitsunish-TD04-TD05-TD06-IHI-SUBARU-Deluxe-/221816198311?hash=item33a54694a7&vxp=mtr
I believe a -3an would be the size, but this sounds like a budget build, so why not try to find the original bolt on piece that bolts onto the CHA and just run a hose to that?
-10an is 1/2" I think and would be a good size for the oil drain.
South Bay Surfer
07-10-2008 10:31 AM
sampol999
09-03-2006 01:09 PM
