Taking out dsm 450's and putting in back Stock Injectors**Quick Question?
Well last night me and Direp pulled the dsm and modified the clips so the honda injectors would plug in, but we got no power so figure mitsubishi and honda is reversed. Can someone confirm this is correct?
Im going back over there tonight with obd1 honda clips and the obd1 injectos and wanted to double check this before, so i dont fry my ecu, by wiring it backwards.
Cliffnotes Does wiring need to be reversed after we clip off the dsm clips and put on the honda clips?
Re: Taking out dsm 450's and putting in back Stock Injectors**Quick Question? (quikb20)
you got the resistor pack or 10 watt 10 ohm resistors already right? so the question is you modified the clip and dont know which way it goes in the injector right?i think if you search there is a diagram or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikb20 »</TD></TR><TR><TD CLASS="quote">Well last night me and Direp pulled the dsm and modified the clips so the honda injectors would plug in, but we got no power so figure mitsubishi and honda is reversed. Can someone confirm this is correct?
Re: Taking out dsm 450's and putting in back Stock Injectors**Quick Question? (InTeGrA B18b1)
Does it even matter if the wiring is reversed? I thought it didn't.
Banned
Re: Taking out dsm 450's and putting in back Stock Injectors**Quick Question? (mos)
yellow/black is the positive, where a resistor box would be wired in line. the other colors go back to the ecu.
hth
hth
Re: Taking out dsm 450's and putting in back Stock Injectors**Quick Question? (Burke)
Yeah the resistor pack is there, we got everything on last night and we cranked and it woudlnt turn over. Looks like it was wired from injectors to resistor pack and then to harness.
If theres one thing i hate its electrical.
I just went out to the car and looked at the AFC it leaned out 30% at 1000 adn 35% at 2000. Is this enough to cause car not to start, this may have been the problem.
and before anyone says anything i bought turbothisls car we pulled the turbo kit off, but didnt have time to do afc and injectors. So last night when the gsr injectors were on it was still running the fuel map from afc. Could this be problem?
the injectors clips does not have any polarity, it wouldn't matter hopw you wired it up. I had lunch with Direp and we kind ahtought it was the setting on the AFC
stan
stan
