t4/60-1 turbo
Re: t4/60-1 turbo (ffgeon)
I drove a T4 60-1 O-trim .58 AR on the street with no problem. It spooled at 4800 on a 81mm bore gsr motor and it is big enough for over 500 whp!
Re: t4/60-1 turbo (SiRkid)
this is my set up
83mm benson sleeve
je 9:1
crower rod
balance crank
port&polish head + 3 angle valve
crower valve, turbo cam, cam gear
str manifold
950cc injector
70mm TB
aeromotive fuel pump and filter
hondata 4b
equal length manifold
t4/60-1 with a/r70
this ir street car and drag sometime
83mm benson sleeve
je 9:1
crower rod
balance crank
str manifold
950cc injector
70mm TB
hondata 4b
t4/60-1 with a/r70
400+. i have a t3/t4 right now and im make 304 whp. so i want to upgrade the turbo when i put in my standalone.
Re: t4/60-1 turbo (CHEAPTURBOdotCOM)
you from cheapturbos.com? can you hook me up with a t4 with garrett turbo bb upgrade? btw whats the gt, why is it so expensive?
Re: t4/60-1 turbo (DubyaAye)
[quote]you from cheapturbo.com? QUOTE]
yep
i wouldnt suggest it for the price and your hp goals.. the t4/60-1 is $725 plus the bb compressor upgrade of $600= $1325
i would suggest the faster spooling, longer lasting gt30 for almost the same price, if you go thru our groupbuy.
the gt series is garrett's high performance turbocharger line. these turbochargers eliminate the use of journal bearings on the shaft, in favor of dual steel ball bearings. most "ball bearing" turbochargers use a ceramic ball bearing, only on the compressor side, and leave the higher friction journal bearing on the turbine side, thus creating more frictional drag and slowing the speed of the shaft. with the dual steel ball bearing in the gt series cartridge, you will have far less frictional drag, creating a faster spool and longer life with the steel instead of ceramic.. pretty much, the center sections are indestructable.
hope this answers your questions.
yep
as the turbo like is it any where near the t4?
sorry dont know much bout turbo sizes.
[Modified by DubyaAye, 8:03 PM 1/8/2003]
Re: t4/60-1 turbo (gsrt)
no i dont think it is too big, i have t-4/60-1 on my daily driver and it dyno out to 506 at the wheel with the wastegate not working,on hondata and limit to 22 pound boost
here is the link to the group buy: https://honda-tech.com/zerothread?id=377933
Cheapturbo.com::
A T04S with and 82 a/r, how would this turbo handle? When would boost come in on a b16? What kind of boost is max on it? Does this turbo have the clamp-on down-pipe? What are all the inlet and outlet sizes??? What else can you tell me about this turbo? I just ordered one and I'll be getting it soon....just wanted to know some more on it. Thanks.
is a t4/60-1 turbo too big for a street civic? its mostly gonna be for drag racing and a little street driving.
Re: t4/60-1 turbo (Civicdrgrcr)
He's trying to take your money eheh.
Showoff
08-17-2003 03:39 AM
