Swap + a question (56k, odubt it)
As some of you may know, this motor/tranny have been giving me alot of issues. It finally went in this weekend, and it fought us every step of the way.
Gsr motor, gsr crank pulley, gsr alternator, gsr alternator belt doesnt work (too long), had to go to 3 places to get a belt that would work.
The other big problem was with the intermediate shaft. It would slide nicely into the tranny, but when we went to bolt it up, it was hitting the block, as in, it would not rotate and be flat against the block. Its hard to explain it, but i had to grind the block down about 1/4" to get it to fit. I got it as smooth/flat as possible and bolted it down tight with a washer setup.
My question is, should this be ok? The shaft spins freely without binding and is very smooth. and yes, this is with a gsr intermediate shaft.
This is all the shavings:
And the best pics i could get with my sucky camera:
I felt so bad putting a fram filter on it, only till i get it running...
Should that be okay?
Anyway heres some pics from the rest of the day:
Action 2md- ready to take some abuse... hopefully
Hopefully i can get it started tonight. Got a few more things to do, and have to find the damn starter.... In another thread i asked if the d and b starters were the same, i was told no. But im just wondering why the autozone part numbers are the same?!?!
Anyway, thanks for looking and any replys, comments would be
Modified by adictionbass at 10:26 PM 1/31/2005
Modified by adictionbass at 10:27 PM 1/31/2005
Re: (Blaze45)
"it came out of a 5 speed 95 gsr". Well the grinding on the block is already done, so hopefully this works out and doesnt cause any more problems...
Location: R.I.P Brian Arbogast...you will be missed, maryland, USA
Re: (Blaze45)
Sounds like you got an auto int. shaft... I would know cause I was sold one..... thats what id say to had the same prob on a buddy LS so we tryed and new one from a 5spd and worked fine.
Re: (TURBO BLUE HATCH)
correct me if im wrong, but gsr did not come in automatic right?
I donno, i made it fit, hopefully it wont **** up my axle positioning....
Re: (adictionbass)
loooks damn good! Thats cool that you lifted the car itself over the motor. Was it easier than straight dropping the motor in?
Re: (1bar)
it sounds like the intermedite shaft is a LS auto.... it might work since you shaved the block you wont snap axles but dont know.... I know a friend had that problem and he broke his axle and diff....... good luck to you and no the D series starter wont work with the B seriers trans
Re: (BoostedEG6)
thanks guys. Picking the car up sliding the motor under, and dropping the car down went farily smooth. When you go in from the top, you have to worry about getting around that tranny mount spot on the frame.
boosted- care to share anymore info on your friends situation?
Re: Swap + a question (SOHC_MShue)
Hopefully ill get the mani and turbo all bolted up by the weekend, and get it started;maybe even take it out for a spin... busy week
Re: Swap + a question (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">Hopefully ill get the mani and turbo all bolted up by the weekend, and get it started;maybe even take it out for a spin... busy week </TD></TR></TABLE>
very jeolous that you have time to put your car together, my car has been sitting motorless for over a month now wait for the rebuild
Re: Swap + a question (BoostedJeff)
well after he broke the diff and axle I took a look at it and the intermedite shaft wasnt staright and I undid it and took it out and saw that it was a auto.... so we put a 5speed GSR and havent had a problem since.......
My car sat for a year and a half with no motor and now I am finally almost done with the motor build
let me know if you need any help
Re: Swap + a question (BoostedEG6)
well what im thinking is that he may have bolted the auto intermediate shaft to the block straight. I could do that, but it wound bind the shaft and it wouldnt spin at all. I can see how that would break a diff. Anyone know if auto and 5 spd axles are the same?
Re: (Project Zero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project Zero »</TD></TR><TR><TD CLASS="quote">Thats nice man, what color paint is it? </TD></TR></TABLE>
Yeah, I love that color, looks really nice. Good choice!
ALMXDUPINTEGRA
05-25-2005 09:35 AM
