Survivability of a mildly built Ls in DE/Auto-x
Alright I'm still in the planning stages of a turbo build-up for a b18a1.
Planned setup: forged rods and pistons w/blockguard rebuilt bottom and top end with later model oil pump, most likely a precision sc34 (maybe sc60) running around 6 on the street, and 11 on the track, oil cooler, 440cc dsm injectors with afc hack and modified timing curve on the ecu, and 93 octane.
I have never and don't plan to drag race this car, it would only be a street car that I daily drive and take to the track about once a month.
Will this set-up be able to withsand the abuse of a monthly DE/TT or would I end up having a car that's gonna be constantly trying to self-destruct.
Any insight or simular setup's and experiences would help.
New User
Re: Survivability of a mildly built Ls in DE/Auto-x (Stubbs)
you didn't mention an intercooler or compression ratio of your pistons....
you also didn't mention your suspension setup... if it just peg-legs and spins the inside tire the whole time your racing then it won't be doing any good...
Oops, I'm gonna go with 9:1 compression, and as for the intercooler, it will be a air to air that can handle output of the turbo at 11psi with a 25% buffer zone.
Suspension I'm not worried about, I've already got that covered.
I'm just worried that this setup won't last 6 months under these conditions.
New User
Re: (Stubbs)
since i can't speak of first hand experiance doing such racing i don't want to waste your time but i will say that, imo, 9:1 would be what I would choose and aas for my question regarding an interecooler... i just wanted to make sure you were intercooling it since i have seen quite a few people run similar setups without ic'ing. have you got an LSD? that's the last thing i could suggest to help you unfortunatly.
-Erik <--- who just thought of cooling... I'd HIGHLY suggest a Fluidyne or C&R radiator...
GEN2 LS
02-03-2010 05:25 PM
