Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Supercharged Boost Gauge install question? (https://honda-tech.com/forums/forced-induction-16/supercharged-boost-gauge-install-question-1189945/)
eg6hatch Mar 24, 2005 10:18 AM
I am in teh process of installing my autometer cobalt series air fuel and boost gauge, electrical is almost done, i hvae the harness to the boost gauge ran through the firewall, my question is, is where is a good vaccum line to tie into, i have never installed one before, and this is a b18c gsr with jackson supercharger, where should i go with the tee for the gauge, thanks alot, pics would be appreciated too. https://honda-tech.com/forums/images/smilies/emthup.gif
eg6hatch Mar 24, 2005 12:50 PM
Re: Supercharged Boost Gauge install question? (eg6hatch)
anyone have any suggestions
HitEm'Up Mar 24, 2005 01:43 PM
1997 Supercharged Acura Integra GSR
233 WHP......163 Ft. Lbs on the Jackson FMU!!! Soon to be tuned on hondata
Nice Numbers!!
PrettyLude Mar 24, 2005 04:41 PM
you can get a vacuum source anywhere after the throttle body, don't spend your money on the cobalt autometer a/f guage, since your spending that much, get a wideband, probably be just a bit more
eg6hatch Mar 25, 2005 09:50 AM
Re: (PrettyLude)
Well I already bought it, but i am planning on getting one, i just got hondata s200b, so i plan to tune on that, and then get one, but i have it so, im going to go ahead and put it in, ok, cool, so anywhere after the throttle body? as in tword the intake manifold right? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JRSChatch &raquo;</TD></TR><TR><TD CLASS="quote">1997 Supercharged Acura Integra GSR
Nice Numbers!!</TD></TR></TABLE>
Thanks, i know i didnt think it would be that high either, there is a dyno video of it on here of it pulling 233, there is a supercharged type r in my city and it only makes 220, but i hope to be a descent bit higher after hondata, and then in may im getting a built lower end, and some head work and running 12-14, dont know yet. https://honda-tech.com/forums/images/smilies/emthup.gif
Rory Breaker Mar 25, 2005 09:58 AM
Re: (eg6hatch)
What pulley are you running?
Just tap the FPR.
eg6hatch Mar 25, 2005 11:42 AM
Re: (Rory Breaker)
I am running the 8 pound pulley, the FPR, please explain!!!!
crxrocks Mar 25, 2005 02:48 PM
Just Tee into the hose between the FPR and the intake manifold. I took a piece of rubber hose just slightly bigger than the nylon hose supplied w/ the autometer units and glued it to the end of the nylon hose. Then I slipped the rubber hose over the Tee.
Chris
Rory Breaker Mar 26, 2005 06:14 AM
Re: (crxrocks)
Right. You can also get a little adapter from pep boys. Just slide the nylon into one end, cut the fpr vac line, tee it, and slide the other end of the adapter onto the tee.
deez92 Mar 26, 2005 07:47 AM
Re: (Rory Breaker)
i took that black plug thing off the back of the manifold.
http://memimage.cardomain.net/member...77_46_full.jpg
eg6hatch Mar 26, 2005 11:13 AM
Re: (deez92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deez92 &raquo;</TD></TR><TR><TD CLASS="quote">i took that black plug thing off the back of the manifold.
http://memimage.cardomain.net/member...77_46_full.jpg </TD></TR></TABLE>
Can you post a few better pics, im interested in doing it that way, it work good im guessing? thanks for the pic https://honda-tech.com/forums/images/smilies/emthup.gif
Tad Mar 26, 2005 12:26 PM
just any vacuum source man!
they'll all show you the same boost.
the line going off the top of the fpr is vacuum
any port off of the back of the intake mani will be vacuum...
basically, hoses only carry 3 things,
air, water, and fuel..
dont get water or fuel and ur cool, haha
eg6hatch Mar 26, 2005 01:14 PM
Re: (Tad)
cool thats what i needed to know, thanks alot man https://honda-tech.com/forums/images/smilies/emthup.gif
deez92 Mar 26, 2005 11:09 PM
Re: (eg6hatch)
http://memimage.cardomain.net/member...77_47_full.jpg
http://memimage.cardomain.net/member...77_48_full.jpg
http://memimage.cardomain.net/member...77_49_full.jpg
sorry i can't get any better pics, i took off the blower off about a year ago. hth dee
eg6hatch Mar 27, 2005 07:10 AM
Thanks for the help guys, and hopefully this will hopefully help first time boost gauge installers like me later https://honda-tech.com/forums/images/smilies/emthup.gif
Jaker Mar 28, 2005 12:22 PM
As long as you're running the FMU, you can tap into the FPR for your boost signal. Once you switch over to Hondata, you will no longer be showing boost to your FPR, so you will need to tap off the back of the manifold to get your boost signal.
Rory Breaker Mar 28, 2005 01:48 PM
Re: Supercharged Boost Gauge install question? (Jaker)
My boost guage is tapped on the FPR and I run Hondata.
Jaker Mar 28, 2005 02:59 PM
Re: Supercharged Boost Gauge install question? (Rory Breaker)
Are you still using the FMU?
Rory Breaker Mar 28, 2005 05:21 PM
Who in their right mind would have anything to do with an FMU with Hondata? https://honda-tech.com/forums/images...s/emsmilep.gif
eg6hatch Mar 28, 2005 07:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Are you still using the FMU?</TD></TR></TABLE>
Yes i am running the FMU, waiting on my hondata ECU but i have the s200b at my house! https://honda-tech.com/forums/images/smilies/emthup.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">Who in their right mind would have anything to do with an FMU with Hondata? https://honda-tech.com/forums/images...s/emsmilep.gif</TD></TR></TABLE>
HUH???? https://honda-tech.com/forums/images...es/emdgust.gif
93turbo16 Mar 28, 2005 08:05 PM
the fmu completely contradicts hondata.
Jaker Mar 28, 2005 09:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">My boost guage is tapped on the FPR and I run Hondata.</TD></TR></TABLE>
I guess my question is: why do you want your FPR to see boost if you're using Hondata? Wouldn't your map sensor, and proper tuning take care of getting the extra fuel into the motor without taking the chance of blowing your FPR with boost?
Rory Breaker Mar 29, 2005 03:51 AM
Your FPR still functions with Hondata....Im not making it do anything it already doesnt do. Im just tapping into it. If I see boost, I see boost. Im assuming that vacuum line is like any other vacuum line at the manifold, it sees boost.
Jaker Mar 29, 2005 06:16 AM
I'm running my FPR off vacuum from the bypass valve housing, just like the bypass valve actuator. That area never sees boost. Its before the blower.
Rory Breaker Mar 29, 2005 08:46 AM
My FPR is run as stock, although I dont remember where I had it tapped with the JRSC, but I did have my boost guage tapped off the FPR with the blower as well.
If your FPR line hasnt been changed, you should be seeing boost tapping into that source.
