Suggestions needed: Novice Honda B18B1 turbo parts gathering
Hey guys so I picked up a 96 integra with a b18b a little while back and have been getting it back on the road runs great gonna end up being what I drive to work I'm really wanting to put a turbo on it and I know I'm probably beating a dead horse here but I dont know all that much about cars worked on big trucks for a while so that's what I'm used to but I'm really not sure what to get I'd like to keep a stock block for now dont wanna run much boost or make a ton of power being it's going to be a daily but I could really use some suggestions I know cheap and reliable don't go together but I dont wanna go crazy and some suggestions on the ecu and tune and injectors and fuel pump would be great thanks guys
re: Suggestions needed: Novice Honda B18B1 turbo parts gathering
T3/t4 turbo cast log or mini ram turbo manifold..... cheap ram manifolds crack walbro 255 in tank fuel pump 450cc injectors replace the factory fuel pressure riser and a fuel gauge ( replacement of the fuel pump will need pressure adjustments) plan on a better clutch small front mount intercooler ‘ECU modification using Chrome software would be the cheapest boost gauge wastegate ( I suggest buying a good buy ) if the wastegate fails the turbo could go full boost blow off valve tap the factory oil pan for the oil return from the turbo 8-14 hours labor this setup will allow you to run 5-8 psi daily safely and most parts can be bought cheap other than the wastegate and clutch |
Thanks you've helped me a lot
Would the rev 9 power kit be good besides a better Watergate
Originally Posted by Billy ray
(Post 51817571)
(Post 51817571)
Go with TIAL wastegate. |
(Post 51817545)
And a basic turbo kit from Go-auto. If you like to use your hands and want cheapest non chinese possible try this assuming again you know what youre doing buying second hand (evo turbo) : https://honda-tech.com/forums/forced...sults-3297362/ |
Originally Posted by Balor_Gr
(Post 51817660)
If you know what you are doing when buying used a set of used DSM 550 injectors work well. Other than that you need a 255 walbro for fuel.
And a basic turbo kit from Go-autoworks |
Sorry about the Watergate I was tired when I wrote that lol I found a nice kit from go auto works for 2,100 thanks for everyones help
(Post 51817669)
(Post 51817669)
Other companies have slowly been dying off, and many struggle to provide the same quality/customer support. I'm speaking in reference to full kits, not just manifolds themself. |
I’d say most major parts from my turbo kit is go-autoworks. Top notch parts never had any issues on my stock b16 running around 250hp street tuned and I drive the hell out of this car lol! I’ve had the parts on my car since 2013. I daily drove it sun rain snow etc for two years. Highly recommend GoAuto. Car is currently in my garage put the key in fire it up and go! |
Re: Suggestions needed: Novice Honda B18B1 turbo parts gathering
Originally Posted by Chance EG
(Post 51817730)
….Other companies have slowly been dying off, and many struggle to provide the same quality/customer support. I'm speaking in reference to full kits, not just manifolds themself.
